Results 1 to 4 of 4
Thread: HUGE Parts inventory clear out: E30, E36, E46, M52, ZF trans, many new parts
    Default HUGE Parts inventory clear out: E30, E36, E46, M52, ZF trans, many new parts
    Cast iron block M52B28- Roughly 105k miles (currently have cylinder head/valvetrain removed): WILL NOT SEPARATE CYLINDER HEAD AND BLOCK $650
    ZF trans, great shape: $400
    E34 oil pan and pickup: $140
    OBDI Harness, complete. In great shape: $100
    OBDII Harness, complete. In great shape: $125 (pending sale)
    E36 AC compressor: $50 (pending sale)
    OBDII ecu: $110
    C101 connector (E30 side) needed for 24v harness: $10
    OBDII Headers: $35
    OBDII knock sensors: $30
    Crank position sensor harness: $10
    ICV and vacuum line, great shape: $20 SOLD
    E36 cyclone separator (CCV) with hose and mounting bracket: $10
    E30 lock cylinder (new): $12
    E30 clutch stop: $5
    E30 door plunger: $1
    E30 trunk plunger: $1
    M20 valve seals (new): $5
    E36 alternator: $30
    E36 motor mount arms (one was cracked and rewelded, can see the crack on the backside): $12
    M20 valve cover: $10
    E36 white base window switches (3): $5 each $10 for all 3
    E30 unlit window switches (3): $1 each
    E30 lit window switches (2): $1 each SOLD
    Hazard switch: $1
    M20 oil cap (new): $5
    M50 manifold and throttle body: $70
    E36 AC compressor bracket and tensioner: $20
    E36 starter: $20
    E30 IX brake booster and master cylinder: $120
    BRAND NEW PARTS:
    Thermostat gasket: $2 SOLD
    Oil filter housing gasket: $3 SOLD
    E30 Clutch master cylinder: $35
    E36 Accessory belt: $10 SOLD
    E30 OEM air filter: $8
    M50/M52/S50/S52 Rear main seal and housing gasket: $12
    M50/M52/S50/S52 pilot bearing: $10 SOLD
    E46 automatic transmission filter and pan gasket: $28
    E34 oil pickup gasket: $1 SOLD
    M50/M52/S50/S52 front crankshaft seal: $5
    M50/M52 oil cap: $8
    M50/M52/S50/S52 clutch bolts: $10 SOLD
    E30 transmission mounts: $10 SOLD
    M52 headgasket set: $165
    M50/M52/S50/S52 head bolt set: $12
    M50/M52/S50/S52 oil pan gasket: $18
    Almost complete shift bushing kit (missing rubber trans tunnel boot and rear shifter mount): $50
    Temp sensor: $8
    Temp sending unit (for 24v swap): $8
    Aux fan switch: $8
    E30 AC belt: $5
    All prices are WITHOUT shipping and are OBO.
    Please let me know if you have any questions
    Thanks
    Max
    Im French! Frög's Avatar
    AMERICA FUCK YEAH
    Where are you located. Interested in a few parts..
    I'm in clemson, sc. Right off 85
    List updated
    Max
