Thread: My '02 Ranger Edge idles rough, help?
    Jul 2012
    Calhoun, Georgia, United States
    Default My '02 Ranger Edge idles rough, help?
    My auto ford edge is killing me that I can't find out what's wrong!
    I have changed the plugs, plug wires, ignition coil, pcv valve and hose. The check engine light went off after changing the pcv valve but still is idling rough and now a tester can't tell me the issue. Oil was changed 2 days ago, the truck has 150 k miles. Any help out there?????
    Swagg.
    LAWRENCEVILLE
    I had a 03 edge with the 3.0 I had pcv hose collapse and caused a few issues. Try reseting the ecu it still might not have cleared the code
    Hella stock member!
    Check for any vacuum leaks..
    Jul 2012
    Will do both tomorrow^ Thanks.!
    Swagg.
    Jul 2012
    When I bought the truck, the guy had no clue the issue but I saw it clearly. The pcv hose was completely melted and when you squeezed it, it felt like bubblegum. I changed it.. same issue... changed the spark plugs, spark plug wires, and got an oil change all together.. still same issue.. Then changed ignition coil.. same issue... So I let my lack of knowledge get the best of me.
    Swagg.
    Quote Originally Posted by Steeze View Post
    No, you did right.. Just check for vaccum leaks and clean Mass air..
    On a side note:
    That intake was bad about leaking, so be smart to have it smoked at a shop, cost very little money.. Or just a can of carb cleaner works..
    Jul 2012
    Thanks for the info man!
    Swagg.
