Results 1 to 17 of 17
Thread: my fuel pump is flooding my carburetor
    Sep 2012
    Roswell GA
    Default my fuel pump is flooding my carburetor
    help!i have an 82 accord and fuel pump was replaced by previous owner....it runs but it pumps to much fuel into my carburetor and floods
    You need to check the float.
    Sep 2012
    Roswell GA
    i was thinking that but the carburetor is new/newly rebuilt!
    and my fuel pump is over flowing and when i put mmy ...fml
    Sep 2012
    Roswell GA
    k ey in the igmition
    You have an adjustment for the level of fuel that sits in the bowl..
    Look into the little window and post back where the level is..
    Sep 2012
    Roswell GA
    do i have to buy a FUEL PRESSURE REGULATOR? the previous owner put the new fuel pump
    or do i need a relay...relay switch or i think its called fuel pump relay ..or regulator ..idk?
    some one help!!
    i got the car running but too much fuel from the pump and idk if the previous owner didnt install right its connected straight to the fuse box?
    Sep 2012
    Roswell GA
    btw the car is an 82 accord
    Sep 2012
    Roswell GA
    Have you checked the Psi from the pump? Not gonna be much, I'd guess 2-5psi.
    Sep 2012
    Roswell GA
    Quote Originally Posted by 1civic View Post
    nope i havent how do i do that
    Sep 2012
    Roswell GA
    i mean i dont want to fuck up my carburetor and the car didnt start so i bought a new battery and distributor and had some guy that knows about carbs ...but didnt rreally know about car carbs and got my car running but he says the fuel pump is sendind to much fuel causing it to flood and when i put the key into the ignition you can hear the fuel pump just pumping with out me turning the car on....im guessing i need a fuel pump relay? but idk how to install that
    Super Certified metalmatt47's Avatar
    Jun 2010
    Powder Springs, Georgia, United States
    Sell the car to someone who knows carbs.
    A relay isn't going to fix your problem. If the pump is working, a relay isn't the answer.
    IF the carb is flooding, it's because the float is stuck and/or sunk in the float bowl. Meaning it either has a whole punched in it, and it's filled with gas and not floating when the bowl is full, or the float needle is stuck.
    Conformity is the jailer of freedom and the enemy of growth.
    - John F. Kennedy
    Just because its a rebuilt carb doesn't mean its adjusted right. Honestly just pay someone that knows carbs to look at it. Assuming it has the correct fuel pump (low pressure) then the only thing that controls fuel level into the carb essentially is the float. So if its flooding thats the first place to look. If youre living in fear, just take it to someone.
    Sep 2012
    Roswell GA
    Does garage zero work on carbs?
    Jun 2010
    Quote Originally Posted by TheATLien View Post
    That's like asking if a duck quacks....
    of course they do. Take it to John and he'll have it running right easy.
    - John F. Kennedy
    Sep 2012
    Roswell GA
    if i can afford it ill see wassup
    because i just lost my job only got bout 200 sumthing so idk
