Results 1 to 11 of 11
Thread: honda trans guru's , question for you..................
    Scottish Scotsman's Avatar
    on the road to recovery
    Default honda trans guru's , question for you..................
    was talking to a guy at work today about draining my trans and using Honda manual fluid in it , he had said that he has always used Penzoil syncromesh in his and said it is way better than the Honda fluid , is there any truth to this? and what are the pro's and con's of it?
    Projects
    I thought the syncromesh was for mainly to lube those tricky worn gears but can be to thick over time and cause more wear. I always searched the same stuff myself and just ended up using Honda MTF anyways.
    GM syncromesh is better, but ether help with grind, and work well for the price... Next best, and what I use is Torco MTF/RTF mix together!!
    but can the syncromesh be used for long term?
    Ive run it in 3 hondas for years, no problem. They make a syncromesh FM (friction modified) that is preferable if you can find it.
    and i refill using only that correct?
    Yes
    You must spread some Reputation around before giving it to green91 again. BOOOOOOOOOOOOOOOOO
    somewhere, GA
    I use half synchromesh and half Honda MTF. Shifting like silk everytime.
    '82 TE72 SR5 Sport Coupe
    3tc
    is it ok to mix them?
    somewhere, GA
    Yep, i have done it in every single Honda i have owned. Its magical stuff...
    3tc
