Make: Nissan
Model: 240sx coupe base
Year: 1992
Trans: Manual
Title: Clean
Miles: 183.xxx on chassis 25k on rebuilt motor
I really just want to see what I can get for my coupe. Not in any rush to get rid of and I don't want to sell, only trade.
Mods:
S14 block bored 30 over
ARP head studs and rod hard ware
Plasma moly rings
Commetic head gasket
Botton mount manifold
Isis 4 inch tip dual exhaust
Greddy mid mount and BOV
Circuit sports 345 lph fuel pump
JWT ecu
550cc injectors
Z32 MAF
KOYO radiator and 16 inch fan
Z32 fuel filter
Godspeed 32 way coilovers
Stage 4 6 puck clutch
Megan adjustable toe rods
EMUSA adjustable traction rods
Eay adjustable RUCAs
Solid engine and trans mounts
Garret t25
Greddy boost controller
NRG quick release and hub and 350 mm deep dish steering wheel
No name bucket seat (sits nice)
Sparco harness
Harness bar
Auto meter gauges
saga electronic gauges
HKS turbo timer
Diff support tie bar
Plate welded diff
18 10.5 rear xxrs in rear
18 8 with 2 inch spacer in front
J30 brakes in front with platinum pads
Sil front conversion
Origin style tail lights
LED converted tag lights
Purple hids
Drift e brake with upgraded cables
Optima relocated to behind passenger
Wire tuck
Sound deadening removed
NEW rods and pistons
New water pump
New out put shaft seal
New lower control arms for front
New starter
Flushed power steering
Change with royal purple every 2k miles
Not one leak at all
Zero blow by
Clevite bearings
K and N air filter
Crackless dash
Gutted on the inside and painted nicely
Im forgetting alot ill add as I remember
Cons, dents in quater panels from fender roll, front fenders are horribly rolled, I was going to get over fenders anyway to fir the wide wheels, stock body can only handle so much haha. Throw out bearing is noisy. Im getting around to it, glove box is messed up, ucket seat needs some loving. But other than that the car is solid as hell. Burns no oil and stays nice and cool
I love this car and its a blast to drive. A t25 on a ka is totally different than a sr, you will have to drive it. A t28 on it would be perfect. I have not real good pics of it but ill post up what I have.
Sorry for the garage pics, these pics do my car no justice what so ever, ill take some nice pics of it and post it up.
Like I said im in no hurry to get rid of, just offer up, things im looking for are sr swapped, mk3 supras, corollas, rb swapped, something of that nature and yes I know my car is not worth a shit ton or perfect. I REALLY want a Subaru, like an early 200o or 90s model. But just offer up.
Offer up, thanks guys! Call or text 770 695 3785.
Sent from my DROID3 using Tapatalk 2
