Results 1 to 40 of 41
Thread: What I've been up to..Eaton 323 build.
    Default What I've been up to..Eaton 323 build.
    It's been an ongoing project for some time now but I'm finally starting to make some forward progress.
    Still working on getting the m112 mocked up. This is the same blower off a lightning or 03-04 cobra with a different inlet.
    So I added a "spacer" and I think it just might work offsetting it over the rear head. Fitting it under the hood would be out the question, but I think I may be ok with that. I figure by time the manifold is made it will be about this tall anyway.
    Here was the clearance with the blower sittting on the valve covers, which was my original plan to sit it as low as possible.
    I'm going to get another manifold to hack up and use the flanges for the supercharger. I'm thinking of something like this, take a stock manifold and cut it down to and mount a plate on top. That way I wouldn't have to modify the rails and all.
    Looking for a spare manifold at the moment. Once that's found I can cut it up and go from there. Stay tuned for updates!
    TOYOTA1515
    This is something different, i like it a lot!
    Got a friend in PR with one but in hatchback, with that engine and individual throttle body that sounds killer and runs in the mid 10's on the 1/4 mile ALL MOTOR!
    SR20 Carbed Datsun B310
    Columbus GA
    seems like a lot of work and money compared to a turbo.
    JEEZUS FLIPPA!!!!!!!!!! Mad fukin respect!
    TOYOTA1515
    By the way if i was you i would start from scratch with the intake manifold instead of hacking that one to fit it, the difference in price is not that significant!
    Quote Originally Posted by dragoncelica View Post
    Leo's gray hatch? Ive talked to him about his setup a few times. That car is nasty.
    turboing this car wouldn't be like turboing a d series. I'd have to fabricate even more because of space. Front and rear turbo manifolds, downpipe, crossmember, all has to be modified or made custom for it to work. If this was a probe or mx6 it would be much easier. I've looked into pros and cons of both setups a few times. Lol
    Quote Originally Posted by Sammich View Post
    Thanks my dude.
    I haven't ruled that out, I was leaning towards using the stock runners just because the flanges were already port matched to my heads.
    ZeroG MainstreaM's Avatar
    Chattanooga
    Oval or Square port? I've got one of each I won't be using. I'm doing the ZE swap in an Escort LX-E.
    Kane
    <a href=http://img140.imageshack.us/img140/6113/normalseqouyah.jpg target=_blank rel=nofollow>http://img140.imageshack.us/img140/6...alseqouyah.jpg</a>
    I need a square port so either ZE or milli will work. Pm me If your willing to part with it.
    That's awesome man. Good to see more people playing with the kl platform.
    Columbus GA
    Quote Originally Posted by DeeAOne View Post
    Thanks my dude.
    na playa.... unlike your groovy supercharger there.... a turbo goes wherever the fuck you want it to go. You aint got to have turbo manifolds to have a turbo.
    LAWRENCEVILLE
    how do you plan to get a belt on it?
    Hella stock member!
    My p/s pump is gutted so its acting as a tensioner right now. Was going to try to use it for that, but that plan might change since the pump is like a 3 rib belt. Lol
    LAWRENCEVILLE
    yeah a 3rib belt aint going to cut it, cobra sometimes have a issue with belt slipping with the large belt.
    Hella stock member!
    Small update. My manifold came in the mail. Normally it would be a sin to cut this up, but there is a crack in one of the runners so it's all good lol. Now I just need to get it to the shop where it will be getting fabbed. I also found a walbro 255 for cheap so that will be going in soon. Now I'm on the hunt for some Millenia S injectors to drop in these rails.
    Cruzan Boy Siverprobegt's Avatar
    ga/VI BREED
    Noooooooooooooooooooooooo!!!!!!!lol
    92 mx3
    IA Member jcatz's Avatar
    Oct 2012
    I'm interested to see how this turns out. This car looks very familiar, I think I bought a pair of bumpers from a relative of yours a few weeks ago. I was in a silver ek hatch?
    I've been looking into SC set ups lately. When making a manifold, besides matching the ports, what do you have to incorporate? I assume there are oil passages, anything else?
    Quote Originally Posted by jcatz View Post
    Hmm.. I doubt it was me. lol
    Mine will be as bare as possible. Any lines will probably be ran externally. At most the fuel rails will run under the blower, but that's about it.
    Car's current position. Going to redo quite a few things while I have it out.
    Are you going to run into adaptor plate/fuel rail clearance issues?
    Glad to see you getting back to working on it. I cringed everytime I saw the wiring, so get it cleaned up!!
    Nah. It will be high enough to clear the rails. I'll have to show you one day. It's much easier to understand in person with a bare manifold.
    Check out the heat marks on my pressure plate. Flywheel looks just as bad. lol
    Certified Gearhead KyleG's Avatar
    Nov 2012
    I've always liked this car! And I like your plans
    ALL CAPS JITB's Avatar
    Louis, you ever look into the toyota sc setup, or the mercedes kompressor, that a few folks have done with the bp. Either way i know you will make it happen! A custom manifold is worse case scenario it seems.
    If its not to late id highly recommend a deatsch werks fuel pump over the walboro!
    Sent from my DROID BIONIC using Tapatalk 2
    Joe I haven't bought a pump yet so ill look into that one. I forgot all about them lol. I thought about using the AC location like everyone does with the clutched m62, but I just don't think I would have the space for mounting down there, let alone piping. If I had the mx6 bay size it would be a no brainer.
    Senior Member SHHHH's Avatar
    Aug 2009
    New York Upstate/ Newnan,GA
    Are you going to run the intercooler under it? If so dont forget about the pump, hoses and a heat exchanger.
    Also port that bad boy before its all said and done. Might as well since its out of the car already.
    2013 GT500
    1989 Mustang 5.0
    Dw has a 3 year warranty! They sold me with that! Lol you need one hit me up! Id look into the compressor setup, if its not to late. Which car is that sc from?
    Aug 2009
    Quote Originally Posted by JITB View Post
    Looks to be an Eaton off a Lightning. The Cobra Eaton has the inlet on the side not the top.
    2013 GT500
    1989 Mustang 5.0
    Quote Originally Posted by SHHHH View Post
    sure is, i didnt even see the SVT logo on it..when i looked at it on my phone.
    Definitely going to port it, but as far as running the midplate and all I was going to try to spray meth to keep heat down instead. Think that alone would be enough? Only reason is because of space concerns.
    Aug 2009
    I dont know. They dont called them HEATons for nothing hahaha.
    2013 GT500
    1989 Mustang 5.0
    I saw that lol. I did a little reading on the stang and lightning forums and there are a few people who swap them onto 2v 4.6L and such and they don't run an IC. They don't run much boost though. Majority were 8-11psi. Most notice quite a difference in power on a hot day though.
    So it's possible, just not 100% efficient.
    Aug 2009
    Looked for some eaton swaps without running an intercooler and I couldnt find any. I did find a good handful of people explaining why it would be a terrible idea though. I know my old eaton setup ran plenty hot with just a pulley. I even have an upgraded heat exchanger. I cant imagine what IATs you would have without running the stock intercooler under it.
    2013 GT500
    1989 Mustang 5.0
    Whats the most boost you would run with non cooled supercharger? - MustangForums.com
    Just one thread. Mixed reviews in that one. Some would some wouldn't. I might just have to suck it up and see what I can do. lol
    Aug 2009
    I ran a non intercooled centrifugal vortech setup on my 2000 Mustang GT and you can tell when it starts to get hot thats for sure. Being that its an Eaton and despite what that one guy is claiming on that website. I wouldnt run it non intercooled. If you plan on pushing any boost through it that will be worth a damn that Eaton will be glowing red.
    2013 GT500
    1989 Mustang 5.0
    Update. Took apart the harness and cleaned it. Plan on taking a lot of wires out of it I don't need.
    Harness nice and tidy! All egr and most all probe related stuff removed.
    The way I put it back together it actually made some of the leads longer so I can tuck more of the main harness behind the motor.
    Next up is completely redoing the charging harness. It has many breaks and splices in it which I think is causing it to burn up over and over again. That and the fact that the KL alternator puts out more amps than a B6 alt.
    Should have fixed this a long time ago..
    Glad to see you putting some time into the ol' gal.
    Just make sure you're ready for the G series to show the Civic tail lights off.
    I was wondering what happen to this car. Gonna be crazy with that s/c.
    About to approach beast mode
    Still got it. Slow going right now. Life getting in the way as usual.
    DON'T SAY ANYTHING ABOUT MY DIRTY INTERIOR! lolol
    Spare block is torn down. Cylinder walls are in pretty good shape for sitting for so long. Should work just fine.
    I finally got around to making some brackets up to put my seat in using my stock rails. I took some steel plating and drilled holes to widen the seat track on one side. Nothing fancy, just want it to work.
    Looks factory where visible.
    Still sitting.
    Columbus GA
    I clicked this thread with great anticipation..... all i got was an updated picture of parts sitting on the ground and some dirty interior. Hurry up!
    keep it up Flipper
    I know I know. I slacked off a lot but I'm focusing more on it now. Still have quite a bit to buy. What did I say about my interior? LOL
    hey was wondering where i can get some of those metal sheet from?
