Results 1 to 3 of 3
Thread: ?!? D15 Mini Me Turbo complete swap and extra parts.... blown head gasket?!?!
    Default ?!? D15 Mini Me Turbo complete swap and extra parts.... blown head gasket?!?!
    I have a Honda d15b7 block with a y8(p2j)vtec head. Today it blew a head gasket, so I am taking the opportunity to swap motors. Has all new gaskets: oil pan, rear main seal, cam seal, valve cover gasket, distributor o rings, and I also have a ton of other brand new gaskets to go with the motor. Has brand new iridium plugs installed. Has an aftermarket adjustable cam gear. Has a 7lb flywheel installed.ARP head studs, Banhof Stage 1 clutch (brand new still being broken in), and I also have another banhof stage 1 clutch still in packaging, has a garrett td05 turbo. Oil pan is tapped and TIG welded. Motor runs fine, just the blown head gasket, so It smokes due to coolant being burnt. In car now can show you it runs. Transmission shift perfect. Stock injectors will be included, or for extra I have the dsm blue top 450cc that are in it. I also have a chipped and basemapped p28 ecu tuned for this setup by Mainstream Performance, two step currently set at 4500 RPMs, and check engine light is used at shift lights at 6500 RPMS. Other parts I have include another complete D16z6 head (minus vtec solenoid), 12 lb flywheel, stock flywheel, another valve cover, a flex plate (for automatic transmission), 2 more accessory pullies, another cam gear, and another alternator.Comes with CV axles also. Make me a reasonable offer I can refuse. No lowballing!! I have pictures can send them through text.
    Attached Thumbnails Attached Thumbnails -wp_000424-jpg
    centre,al
    You need a price bud
    Norcross
    and pics of everything you're attempting to sell?
