Results 1 to 3 of 3
Thread: Head gasket
    Jul 2009
    Default Head gasket
    What does head gasket thickness matter?
    Sent from my SGH-T959 using Tapatalk
    Thicker headgaskets lower compression, thinner headgaskets raise compression.
    I never believed in messing with headgasket thickness, too many problems with it. Always run OEM
    Jan 2010
    We can do business
    You can do it safely. You can buy 2 layer hg's, or take one off yourself, etc... Make sure you check your compression before you do tho. Torque the head right and you should be good.
    As Vteckidd said, thick = lower compression... thinner= higher compression
