Results 1 to 1 of 1
Thread: Built b20vtec almost swap
    centre,al
    Default Built b20vtec almost swap
    Lowballers welcome here send me your offers
    Location centre al close to Rome ga will meet at a reasonable distance
    Whats included
    gsr head freshly re built (complete)
    gsr cams
    distributor
    B starter
    b alternator with bracket
    Both new axles and mid shaft
    Gsr shift linkage
    Blox intake manifold with iacv and throttle body
    rmf rep header
    B20z2 block
    Arp rod bolts
    Acl race bearings
    New honda Gaskets
    Rs machine 84.5mm Itr style pistons
    Je piston rings
    Balanced bottom end
    New Honda oil pump
    new Honda water pump
    arp head studs
    stock b series clutch ad flywheel
    Harness
    engine made 230 wheel at main stream with different gsr with skunk 2 tuner 2 cams and valve train
    built by starrfire
    this is a very clean engine very well built
    1800 OBO!!!!!!
    also can include b series Ek mounts
    basically all you need is a trans an ecu and your ready to go
    there is well over 3 k in parts machine work etc
    trades accepted full d16z6 or y8 swaps plus cash clean shell plus cash depending on shell
    Text or call me anytime for more info 256 557 6212
