DFI 661FX-TML LGA775 SIS964 800FSB 2DDR MATX ADUIO VGA LAN SATA RAID 3PCI 8X mATX
DFI 661FX-TML LGA775 SIS964 800FSB specification
http://www.computerhq.com/DFI_661FX-...id-540687.html
General:Processor:Socket LGA 775 (LAN Grid Array) for IntelŪ PentiumŪ 4 Prescott processor
- Hyper-Threading Technology
- 533MT/s and 800MT/s (200MHz) system bus interfaceChipset:North bridge: SiS 661FX
South bridge: SiS 964Memory:Two 184-pin DDR DIMM sockets
Supports 4 banks up to 2GB using PC1600 (DDR200), PC2100 (DDR266), PC2700 (DDR333) and PC3200 (DDR400) unbuffered DDR SDRAM DIMM, 2.6V typeBIOS:Award BIOS, 2Mbit flash memoryAudio:AC'97 2.2 extension compliant codec, S/PDIF-in/out interface, 6-channel audio outputLAN:Phy fast ethernet controller, Supports 10/100MbpsIDE:Two IDE connector supports up to two UltraDMA133Mbps hard drivesSerial ATA with RAID:Supports two Serial ATA interfaces which are compliant with SATA 1.0 specification (1.5Gbps interface)
Supports RAID 0, RAID 1 and JBODAGP:Supports AGP 3.0 (AGP 4x and 8x) and AGP 2.0 (AGP 1x and 4x) spec.
Supports 1.5V AGP 8x (2.13GB/sec.) and AGP 4x (1066MB/sec.) Rear Panel I/O Ports:1 mini-DIN-6 PS/2 mouse port
1 mini-DIN-6 PS/2 keyboard port
1 DB-25 parallel port
1 DB-9 serial port
1 DB-15 VGA port
4 USB 2.0/1.1 ports
1 RJ45 LAN port
3 audio jacks: line-out, line-in and mic-inI/O Connectors:2 connectors for 4 additional external USB 2.0/1.1 ports
1 front audio connector for external line-out and mic-in jacks
1 CD-in internal audio connector
1 S/PDIF-in/out connector
2 Serial ATA connectors
2 IDE connectors
1 floppy drive connector
1 20-pin ATX power connector
1 4-pin ATX 12V power connector
1 front panel connector
2 fan connectorsExpansion Slots:1 AGP slot, 3 PCI slotsPCB:microATX form factor, 24.4cm (9.6") x 20cm (7.87")
Asking 40$ Shipped. I can ship, or you can meet up and pick it up, Brand new in box.
Im also paypal verified
