Results 1 to 4 of 4
Thread: FS FT: fully built N/A h2b swap
    revolution big mac's Avatar
    Default FS FT: fully built N/A h2b swap
    Block cleaned and decked
    h22a
    evolution crank pully
    innovative alternator relocator
    f22 crank micro polished
    f22 h beam rods
    arp rod bolts
    make it a 2.3L
    h22 type s pistons
    (12.2:1 compression)
    kazien speed balance shaft delete kit
    honda manual tensioner kit
    Head cleaned reserfaced
    h22a
    arp head studs
    skunk2 pro series valve train
    skunk2 pro1 cams
    skunk2 cam gears
    skunk2 70mm throttle body
    skunk2 pro series intake manifold
    aem fuel rail
    aem rpr
    dsm 450cc injector
    3" intake with velocity stack
    rmf replica header modded for h2b
    3inch exhaust
    qsd h2b kit
    b16 tranny gsr 5th gear oem lsd
    hondata s300
    competion clutch stage 4 clutch
    10 lbs flywheel
    arp flywheen bolt
    axels
    radiator fluidyne
    new alternator
    new oil pump
    new water pump
    7k miles on build, everything is new
    tuned by import experts winder ga 235whp 179 tq
    $4600
    Mar 2012
    Willing to part any items? Interested in the Hondata
    no sorry
    Mar 2012
    No problem. GLWS and let me know if you change your mind
