Results 1 to 29 of 29
Thread: Fs: EK BUILT K24 ALL MOTOR PARTOUT
    columbus, ga
    Default Fs: Silver 96 EK CIVIC 99-00 Front/Rear Converted, BUILT K24 ALL MOTOR PARTOUT
    I'm parting out my all motor race car. everything on the car is in perfect working condition with only a few dyno pulls and 1 track day on it.
    before i take parts off the car i would like to sell the motor and header
    87.5 bore 13.7 compression wiseco pistons
    carillo pro light weight rods
    acl race bearings
    k24a8 block with vin still attached 100% legit was hot tanked and bored to 87.5 and balanced
    all new k20a2 oil pump, chains, guides, tensioner
    k24 oil pan
    k20a2 head
    arp head studs
    head has 3 angle valve job
    supertech dual valve springs and retainers
    skunk2 stage 3 v3 cams
    k24 water pump
    oem coil packs and valve cover
    will part out the block for $2500 and $1300 for complete head with cams and valvetrain, valve cover, coil packs etc
    or $3250 for the whole longblock
    or $4000 with an asp ceramic coated header
    other parts i have for the car
    k-tuned ac/ps delete $150
    rc 750cc k series injectors $300
    ported rbc manifold $400
    hasport new version ekk2 mounts $400
    competition clutch twin disc $800
    asp k20/k24 4-1 race header with reverse megaphone and vband flange and clamp $850
    oem rsx-s shifter cables $150
    oem shifter box $40
    k series starter $50
    K series alt $75
    braided stainless clutch line $25
    the shell has a clean title its a 97 with 99-00 front and rear
    black housing headlights-stays with shell
    skunk2 pro-c fully adjustable suspension $750
    pic select 12k front 18k rear suspension $750
    skunk2 gold lca $150
    skunk2 rear camber kit $100
    skunk2 front camber kit $100
    vis carbon trunk and fal rear window $600
    carbon wing $200
    carbon front grill 99-00 $50
    black ge rear bumper diffuser on the rear bumper-stays with shell
    99-00 si gauge cluster 47999 on the clock! $150
    si front seats 99-00 $150
    si stock radio 99-00 $50
    roof is painted black
    oem mirror blockoff plates $50
    stock rear seats-not installed $50
    stock rear plastics-not installed $50
    stock door panels-not installed $75
    removed sound deadening
    rear deck lid/privacy cover-not installed $100
    gsr rear brakes w/ drilled rotors and aem brake pads and brand new trailing arm bushings $200
    gsr front calipers w/new dba kangaroo paw rotors and new pads $300
    r-crew shifter plate $100
    walbro 255 fuel pump in the tank-stays with shell
    aeromotive fuel pressure regulator and inline fuel filter and braided black fuel lines $300
    wire tuck and brake line tuck
    remote mounted battery terminals and custom battery mount under passenger headlight-stays with shell
    3 inch mandrel bent exhaust with vibrant black muffler- not installed SOLD
    eg front crossmember/control arms/rack and pinion-stays with shell
    hybrid racing sub harness for k series $275
    modified radiator with fan and hoses $100
    rsx steering wheel with jdm honda airbag $200
    needs a new driver side window regulator-the threads where the handle goes are stripped
    the price on whats left of the bare shell depends on what you want on it.
    right now the car is ready to drop in a motor, tranny, and kpro and ride
    i think that's it. my cell is 706-593-7507. txt me with any questions you may have or if your interested in something. Like i said the motor and header will need to be sold first before i part the rest of the car out. thanks ~ Matt
    disregard the torque, it wasn't reading right on the dyno for some reason
    nice parts list, i might have to pick some that stuff up if i start working soon. GLWS...
    About to approach beast mode
    bump for midnight
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    BSERIES VS THE WORLD top_speed's Avatar
    Bump for a good seller
    Team Jdm Junkyz
    Wait.....i dont know if i cant see it but whats the price of the shell?
    columbus, ga
    Quote Originally Posted by anthony2012 View Post
    it depends what you would want on it. pm with that info or text me and i'll give you a price
    Certified Gearhead UWISH's Avatar
    Aug 2010
    NEAR YOU
    do you want to sell the radiator and fan
    columbus, ga
    Quote Originally Posted by UWISH View Post
    yep i will part everything out on the car as soon as i have a legit buyer for the motor and header
    How much for the header?
    columbus, ga
    Quote Originally Posted by K24cb7coupe View Post
    $850 for just the header
    how much for the way the car sits right now with everything
    columbus, ga
    Quote Originally Posted by Boosting EG View Post
    9k obo
    Jan 2010
    ATLANTA
    Wats the least on the ported rbc manifold
    columbus, ga
    Quote Originally Posted by egBOY View Post
    $400, the porting alone was $500 and the manifold was $185 new
    Dec 2008
    Northside
    why you parting out? and also let me get a price of fuel setup
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    columbus, ga
    Quote Originally Posted by *EFilliated* View Post
    i just lost interest in the car, and i have other k series projects i would like to finish.
    columbus, ga
    columbus, ga
    night bump, everything is still up for grabs at the moment
    Boooosted!! kr3w108's Avatar
    Oct 2008
    Bama
    Someone buy the motor already ... Lol bump for you sir. To thA top ....
    Best ET 9.69@147 running out of gear....
    video of pass....
    https://youtu.be/Y4ogpwzNpzg
    Class of 2010 Ch0psticks11's Avatar
    Queen City
    how much for the bottle of rain-x? is it full or used?
    Parental Advisory Dennnissssss's Avatar
    are you selling the cf trunk? LMK ASAP inbox me
    Hamilton, GA
    Boo
    columbus, ga
    up
    u selling the trans?
    I don't drive a ricer, I drive a f*cking RICER!
    columbus, ga
    not at the moment, what type of trans are you looking for? 5-6 speed? lsd?
    columbus, ga
    Aug 2012
    Default eg susp..
    Hey… for those eg suspension parts… upper or lower control arms?
    columbus, ga
    Quote Originally Posted by mberzse1 View Post
    lower
    Quote Originally Posted by k24eg View Post
    i'd like a 6 speed, but a 5 speed will be fine.
