Results 1 to 5 of 5
Thread: Civic won't start with key.
    center field
    Default Civic won't start with key.
    Like it says won't start with key.95 civic .when I bought it ,it had a push start .I checked the rubber tab on clutch peddlel checked fuses everthibg any idea what it may be ...is there a starter relay and if so where . Any help would be great.
    Feb 2012
    loose connection on ignition module? wrong key?
    Conformer.
    center field
    I'm sure it's the rite key . .and I'll check connection
    unplug safety neutral switch and put a jumper wire..
    also was car an auto converted?
    And yes there is a fuse under the dash, says starter signal
