Results 1 to 18 of 18
Thread: turbo?
    Certified Gearhead jimjam187's Avatar
    Default turbo?
    car wont build over 8 psi.
    ALEX #1Beaver's Avatar
    like that car saw you at northlake mall
    Banned Jon00's Avatar
    Dec 2003
    Grayson, GA
    Quote Originally Posted by jimjam187
    need more info then that
    Barrett Parkway, GA
    ^^^werd^^^
    cause thats what the wastegate is set at dumb ass.
    Greddy Type s bov, tial 38mm wg, t3 turbo, turbo xs duel stage boost cont.
    when I turn up the boost nothing happens.
    Barrett Parkway, GA
    so that's the only thing...nothing else happens? no white smoke...nothing? everything is perfect except the fact it won't boost past 8lbs?
    yup this is a complete new buildother then the turbo setup came off another car of mine but all worked fine before., no smoke nothing. You have no reason to call me a dumb ass
    hwen it was on the dyno when we turned up the boost the hp went down, and still kept the 8lb level?
    Barrett Parkway, GA
    hmm...yeah...only thing i can think of would be the waste gate...or a leak somewhere
    thanks for the help
    sTILL NO COMMENTS? BUMP...
    because its the fuckin wastegate
    Whell MR. Einstein SO if iI go out and buy a wastegate and that doesnt work I can come take it out of your ASS? Just wanting to see if n e 1 else has had this problem. Because Ive had people tell me it could be 1 of 4 thing wrong. So unless you know for sure quit jacking my post ass hole!
    what psi ring do u have in your wg? are u 110% sure your boost controller is working right?
    Jay, CEO of S.C. Chapter 1/4Mile's Avatar
    Myrtle Beach
    Ifyou have 2 nipples on your wastegate make sure you use the top for the boost controller the bottom you use only if you and running off the WG spring which, I'm going to go out on a limb and say its a 7-8lb spring.
    "I be on the that Boostanite"
    8lb spring It wont build boost past what the wg is set @. The turbo XS people told me to hook the boost controler to the bottom, I thought the top 1 was for the electric boost cont?
    Myrtle Beach
    Electronic or manual they both do the same thing, and the top nipple is for that. If you hook the bootm up you are only going to run off the wg spring.
