Im selling my 1999 Honda Civic EX 4 Door. Sleeper $4500
GOOD:
ONLY 87,500 original miles
Engine is modified 2.2 Liter
The H22 is a 1997 model
5 Speed Manual transmission
Stage 3 Clutch
Civic SI grill, headlights, and fog lights
Aftermarket Tail lights
Golden Eagle Rear Diffuser
Skunks2 Suspension Arms and Shock assemblies all around
Tokico Blue Shocks
Drilled and slotted Rotors
HKS Drager Exhaust Tip
Rota Wheels (not sure what type)
Pioneer Stereo
A-Pillar gauges for OIL PSI and Water Temp
Aftermarket Alarm System
ENGINE MODS:
H22A 1996 Model (Closed Deck!)
Skunks2 Adjustable cam gears, Springs, retainers, and Cams. Not sure about valves
Skunks 2 Intake manifold
Bigger Throttle Body (Not sure of brand)
AEM Fuel Rail
AEM Adjustable Fuel Pressure Regulator
Larger Injectors
Light weight flywheel
OBX Header
Aftermarket engine Mounts (Done right)
Bigger Fuel Injectors and Adjustable Fuel Pressure Regulator
Moroso Oil Pan with Pre-Tapped hole for Turbo Oil Return
As far as internals go I'm not sure i haven't broken it down yet.
Not sure if transmission has LSD either
Hondata S200
The BAD:
Needs tuning. Runs and drives fine just under heavy load in 2 gear v-tec breaks up. I plan to get it tuned just haven't had the time yet.
Paint on one or two of the wheels is starting to flake
Fenders have a few dents and rear bumper has a small crack.
Im open to trade offers. Price is somewhat negotiable. If interested call or text at 478-607-0086
