Thread: where to get a broken stud/bolt fixed/replaced?
    Default where to get a broken stud/bolt fixed/replaced?
    i have a 1997 honda civic lx completely stock. all original parts from 97. i decided to lower the car on coilovers but ran into some problems. i broke the stud on the long bolt threw the lca and struts. ive read up online to use easy out tool but do not have the knowledge or tool or confidence to do so. does anyone have the material to do this type of job or can send me that way? the car is currently in the dunwoody area so i prefer not to travel far in it. or if someone mobile can come and do the fix. call or text 478-284-2463. thank you
    Feb 2012
    drill a hole into the center of the broken stud, get an ez out bit from napa and jam it in the hole. Put your drill in reverse, bam!
    Stay Humble
    WV
    Not trying to be a jerk, but if you have the confidence to lower a car then you should have the confidence to fix this.
    ^x2
    fair enough.... i don't have any power tools tho. im doing everything by hand n a breaker bar.
    Earth
    Even better.
    Procedure is still the same.
    05srt4
    Jun 2009
    Upatoi, Georgia, United States
    i just normally use my dremel and make a flathead out of the broken stud...but most cases that wont work
    Your mom's bed
    If u broke the head of the bolt off then ur not going to get it out with an EZ-out, it's going to break off too. U can try to cut the nut off that's welded on the fork of the strut or ur going to have to buy new struts and cut the end of the fork off with the nut welded on, U can use a hack saw but that shit will take forever. I'm assuming this is for the rear correct?
