Results 1 to 14 of 14
Thread: Need Crome tuner ASAP!
    Default Need Crome tuner ASAP!
    As title says, I need my LS/VTEC (N/A) tuned ASAP. I have already contacted Scotty multiple times with little luck so who else out here tunes Crome? Not looking to go broke over a tune either. Post or PM me.
    Scotty had surgery, and will be out until next week. If he hasn't answered its because he is on meds. Also if you have Crome Pro/free someone can tune it Nobody around has Crome Gold that I know of besides us.
    Who else tunes Crome Pro around Cobb then? And how many hours does it take to tune my N/A setup (LS/VTEC, stock cams)?
    Southern Speed
    Macon
    usually only take up to 2 hours from what ive seen
    Quote Originally Posted by KevinT707 View Post
    If you're in that much of a bind put a stock gsr ecu in it and ride.
    I would, but I'm running 310cc injectors so I'm not sure how that would play out.
    download Crome free, load GSR map, scale injectors to 310. problem solved.
    Or take it to any of the tuning shops that have been in business for the last decade and get it tuned.
    You're just always so wise Mr. Mike *high 5*
    NITROUS JUNKIE
    home
    import expert mony could tune it
    You ask questions you know the answer too
    Quote Originally Posted by EJ6 View Post
    They're dyno was down on Monday so that was a no go.
    I actually didn't know. I know very little about Crome, plus I don't really mod my car anymore. I just care if it runs & gets good gas mileage
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    Crome is awesome
    just download some maps from honda-tech- i'm sure there's a 310cc map already out there, or do as vteckidd posted (i attached a obd1 gsr map)
    get some chips from Fry's electronics or Radioshack, burn one using youtube method, pop it into the socket on your socketed ECU = done
    You can have a baseline semi reliable chip, and then one to experiment on while datalogging. Unless you're beating on the car all day, it doesn't have to be perfect.
    or...
    http://static.moates.net/zips/crome/...ME%20v1.06.pdf
    Also, check out PGMFI.ORG
    Attached Files Attached Files
    ATL represent
    It's not that tough.
    You can do it yourself.
    I have crome pro and a chip burner if you want me to show you how to tune your setup yourself.
