Results 1 to 3 of 3
Thread: 96 coupe b18b1
    Apr 2010
    Griffin,Ga
    Default 96 coupe b18b1
    ok here is the problem i have a 96 civic coupe with a b18b1 it has a cel for the front o2 sensor heater will this cause it to skip or is there more problems like wiring.......
    an o2 heater code won't make it skip.
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    You either have a problem with the heater circuit running through the o2 or an electrical issue. First thing you need to do is unplug the o2 and test continuity between the two heater terminals on the compnent side of the plug. Do this when its cold. You should have almost direct continuity. If you dont, replace the sensor. if you do, check your wiring.
    98 Acura Integra LS-DD
    ??????????????????-project
