Results 1 to 14 of 14
Thread: 1996 Honda Prelude Si
    Drama Free Queen T-Mo Goodie's Avatar
    Default 1996 Honda Prelude Si $2600 OBO
    EDIT 8/23/12: Newer post locked, don't know why, so I'll edit this one. CAR WAS RECENTLY STOLEN AND RECOVERED! FROM WHAT I CAN SEE, STOLE THE DRIVERS AXLE, STOLE ECU, STOLE A SI WHEEL (but put a full size spare on it), and UNBOLTED/STOLE THE CAT CONV!!! IT WILL NEED TO BE TOWED. TITLE IS CLEAN, BODY IS CLEAN, INTERIOR STILL THERE, MOTOR AND TRANS STILL THERE UNTOUCHED. I CRUNK IT UP OVER THE WEEKEND!!!! I fixed the ignition switch and I got an OE ECU on the way....ASKING FOR $1000 firm as is Price will go up as I continue to bring it back to life.
    Tesha 404.957.0010
    I am thinking of letting my project Prelude go. I will possibly be moving out of the state and won't need this vehicle anymore.
    A little info about the car. Bought it from a guy who was having some health/financial problems. From my understanding the engine was rebuilt. Someone had stole the catalytic converter. Upon further inspection of the vehicle, I learned that a lot of stuff wasn't connected correctly. The car ran like crap and then finally died and wouldn't start. I then dug into my helms manual and found out that the computer took a crap.... It runs fine now. I just haven't figured out the routing of some of the vacuum hoses.
    5 Speed Manual
    139K miles
    VIN # JHMBB2150TC002745
    Interior is clean -Tan
    Exterior is clean- like a Pewter color
    Power steering is working
    A/C blows but needs charging
    P/W, doors, and sunroof works
    Cruise control
    H23 motor
    Pros:
    New TPS
    New Crank position sensor
    New ECU (had to use conversion harness)
    Replaced exhaust piping and catalytic converter
    Replaced Axles
    New water pump
    New timing belt
    New Distributor cap/rotor
    New NGK plugs and bosch wires
    New A/C, Alt, and P/S belts
    New short ram intake
    New battery
    New clutch slave cylinder
    New clutch
    New master cylinder
    New Intake air temperature sensor (burnt up because they had the plugs crossed with something else)
    Coolant system flushed
    Recently changed oil and filter
    Cons:
    Gas gauge works when it wants
    ABS light is on
    Trunk open light stays on (haven't had a chance to research why)
    After changing ECU, its getting a code 9 (haven't had a chance to see why)
    Leaks a little oil from the cam cap seal near distributor. No other leaks
    The car runs fine. I have just been toooooo busy with work that I haven't had time to play with it. Engine runs smooth and transmission shifts like butter. The IAB (intake air bypass) box was missing from the back of the intake manifold, but I finally got one (which was extremely hard to find lol) and that's what I have to route the vacuum wires for. Other than that it is still pretty much stock. I replaced the two front tires and it will need two for the rear. Thats all I can think of for now..... Letting it go for $1000 FIRM AS IS
    More pics come soon, gotta go snap some newer ones......
    Last edited by T-Mo Goodie; 08-23-2012 at 08:07 PM. Reason: started fixing some things
    '06 Infiniti G35
    '96 Honda Prelude (project)
    www.twitter.com/tmogoodie
    GWINNETT IS GREAT!
    wow..its soo beautiful...
    good luck!
    Feb 2012
    nice! seems like great dd
    Thanks guys. Wednesday bump!
    '06 Infiniti G35
    GWINNETT IS GREAT!
    i have the lowest chance of getting rid of my lude when in the same market as you guys...
    Flush TSX JDMEK18's Avatar
    car looks clean, i'm going to be in the market for a dd when my car sells / can u send me some pics of the interior and engine bay please 678-779-8423 / Terry - thanks
    GLWS looks clean, seems like some minor issues. that code 9, according to google CYP sensor...cylinder position sensor? seems like a cheap fix.
    STOLEN!!!
    '06 Infiniti G35
    lol you owe me
    #NF Tmogoodie lol
    Need this gone! I am not gonna put anymore money into it. Selling as is. Very good deal
    '06 Infiniti G35
    No one likes Preludes anymore?
    Ignition switch: $22.99
    CV Axle: $47.99
    ECU: ??? Most ppl selling for $40-100
    Cat conv: depends on if you want oe or aftermarket: $267.99 OE $30 eBay
    Not much money needed to be running again. I'm just not in town anymore and don't have time to put it back together
    '06 Infiniti G35
    It crunk up over the weekend while I was in town!! Ignition switch fixed and OE ECU (integra ecu works also) on the way. Bump
    '06 Infiniti G35
    Winder,Ga
    Quote Originally Posted by T-Mo Goodie View Post
    Get crunk!
    It's not the speed that kill's its the sudden stop at the end.
