Thread: my car wont start
    Sep 2009
    JONESBORO
    Default my car wont start
    okay well i went to the store and left my lights on so i thought my battery died so i jump started it and nothing so i changed the starter and the main relay still wont start all i get is a lil clickin in the fuse box under the hood please help will pay if u get the car turned on
    Scottish Scotsman's Avatar
    on the road to recovery
    more info on the car? make , model , swapped?
    somewhere, GA
    change your flux capacitor!
    For real tho, your battery is prob so low it wont jump. Get some good(not cheap) jumper cables and let it sit charging from other vehicle for bout 10 min then crank. Or get one of your homies batteries that works and put it on yours and see if it cranks. I accept cash or credit! PM for billing info.
    '82 TE72 SR5 Sport Coupe
    3tc
    Sep 2009
    JONESBORO
    acura integra gsr with a lsv
    Stang Mod slostang's Avatar
    Southside
    Sounds like you have a locked up piston return spring causing the motor to seize. Best price i could find on them is here...
    Piston Return Spring - $54.99 : KaleCoAuto.com, Your home for the rare, unusual, and hard to find auto parts.
    IA's Delivery Expert AfroMan's Avatar
    Aug 2009
    Duluth
    Buy a new battery man. That happened to me, tried to jump and still wouldnt start. Your battery is probably toast. I bought another battery and bam, fired right up.
    Sep 2009
    JONESBORO
    i went and they tld me it was good
    are you getting pwr to the starter? does the fuel pump hum when you turn the key to ign?
    somewhere, GA
    make sure your battery terminals are clean
    3tc
    If its just clicking its not getting power.. Try and push start it. If it will roll start run a push button to starter and bam!
    Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
    Senior Member JDMJ's Avatar
    Jun 2009
    Cedar Bluff, Alabama
    Quote Originally Posted by ekorgohome View Post
    i do know one thing..The people in bama that work in parts stores belong on a farm. Go to numerous places, get it tested. I had a bad alternator* but he kept telling me it was fine. ( hooked it up wrong.) I know its hard to hook up a battery wrong but fine another battery first. Without 12v, your stuck right there.
    Sig too big
    -IA Management
    Originally Posted by tnomud
    Aren't all IA HOndas 11-12 second cars?
    Sep 2009
    JONESBORO
    its push button now guys but thanks
