Results 1 to 2 of 2
Thread: FS: R134a AC system pulled from my EG Hatch (factory R134a)
    MIA-ATL
    Default FS: R134a AC system pulled from my EG Hatch (factory R134a)
    Like the title states, the following came out of my Hatch. It should be a perfect bolt-in affair for all 94-01 Integras and 92-95 Civics.
    I am fairly certain it's a bolt-on for 96-00 Civics too, either way, look it up first to make sure.
    Everything worked before I pulled it a couple of weeks ago, but I recommend new expansion valve and dryer before you put it on your car.
    - Evaporator assembly with two expansion valves (in case you want to try cleaning one, but they're cheap new anyways)
    - TWO Condenser fans (one from the Civic, might need new motor, the spare one from an Integra - works perfectly)
    - Original OEM AC Compressor (old oil inside, I will provide you with fresh PAG46 oil that cost me $15)
    - New set of AC O-rings, I also have the old dryer, but get a new one
    - I might have more, I need to check
    $150 cash, I can meet you somewhere around Cobb/Cherokee county.
    If interested, text: 786-2oo-ThreeThreeTwoOne
    Thanks.
    '93 Civic CX HB
    MIA-ATL
    TTT
    '93 Civic CX HB
