Results 1 to 15 of 15
Thread: Stripped the allen wrench socket out the top of my strut...
    Feb 2012
    Default Stripped the allen wrench socket out the top of my strut...
    I was lowering my del sol today and stripped the allen wrench hole out of the top of my rear strut. It had been completely rusted out -___-
    Is there anything I can do to fix this without having to replace the strut?
    Conformer.
    TheMyth
    Might could try using a strong impact.
    Certified Gearhead sang's Avatar
    Nov 2009
    stockbridge
    Quote Originally Posted by Berta View Post
    x2
    Feb 2012
    On top of the strut, there is a 14mm nut over an allen wrench socket. You have to hold the socket in place with the allen wrench while you unscrew the 14mm nut. And even if I got that off, I would be reusing that strut and have to replace the 14mm nut while using the same method with the allen wrench. An impact gun would do anything for me :/
    Conformer.
    Columbus GA
    id love to meet the person who invented allen wrenches so i could punch him in the face.
    Atlanta... everywhere on i85
    Quote Originally Posted by CDangerfield View Post
    Impact will do it, I've had this problem many times
    2 low 4 common sense PTCDC5's Avatar
    Absolute worst case scenario you can use a Dremel to cut a slot across the fastener. Then use a very wide flat head or something to that effect to hold it still.
    Feb 2012
    Well I guess I'm stuck...I don't have an impact, and a shop is trying to charge me my left nut...new strut it is!!!
    Conformer.
    theMagician JGilbert312's Avatar
    Feb 2010
    Calhoun, GA
    I used vice grips when mine did this, locked on under the nut somewhere and held it
    Norcross
    Quote Originally Posted by PTCDC5 View Post
    I'd do this before i bought a new strut, jussayin.
    It's all about JDM.
    CA to GA
    But you have to spray some WD-40 or PB Blaster to loosen up the rust. But eventually the nut will get stuck at the end. Just cut the nut in half. and pry it off.
    It's all about JDM.
    CA to GA
    if you use a vice grip, you'll end up stripping the threads... I had same scenario on a lower sway bar that had McAllen slot (it stripped too). I ended up cutting the whole thing off, because everything was rusted, and I replaced it with a new set up.
    if it is rusted that bad you either can clamp vise grips on the shock shaft somewhere OR cut off the nut entirely. either method will pretty much ruin the shock... but as it is rusty anyways just replace it
    __DailyGrind
    Feb 2012
    Thanks guys! The nut wasn't rusted, the allen wrench socket was. I ended up drilling it out and using an extractor tool to hold it hahaha. WORKED LIKE A CHARM!
    Before:
    After:
    Conformer.
