Results 1 to 5 of 5
Thread: Problem with my 94 civic ex
    Default Problem with my 94 civic ex
    Here's the problem.Ever since I bought the car,it would every once in a while,while at a red light or stop sign,the car would turn off,and I would have to crank it up again..Or even while driving on the freeway,I would coast in neutral,and it would turn off..I would have to put back into gear to be able to accelerate again..About a month ago,I noticed the car would turn off just about every time I got to a stop,but not if I just turned the car and let it idle...Since purchasing a new car,I didn't drive the one with the problem for like 5 days..When I went to turn on the car,no power..No lights,radio,and would not start..It jump starts right away tho with jumper cables..If I turn the car off,it will not crank start again..Anybody know what it could be maybe?
    Certified Gearhead oreign's Avatar
    May 2011
    ignition switch/main relay maybe?
    Sounds like bad battery terminals. Check them and clean them with a wire brush. A battery with a bad cell / intermittant short can cause similiar symptoms.
    somewhere, GA
    I agree. Start with new terminals and clean your battery posts. New terms are like $5 at autozone
    '82 TE72 SR5 Sport Coupe
    3tc
    Supposedly it's having electrical problems whatever than means..I'll probably try taking off the battery terminals from my other car that works fine.
