Results 1 to 4 of 4
Thread: S14 1JZ WIRING HELP!
    Default S14 1JZ WIRING HELP!
    LOOKING FOR ANY INFO ON WIRING 1JZ IN S14.
    LIKE WHAT? MAKE SURE YOU USE INSULATED WIRE. A LOT OF IT.
    That's all the info i've got.
    Need to know what is needed to power up ecu ignitor coil injectors ext to get it running
    Certified Gearhead kevint2's Avatar
    Mar 2012
    In most cases on 1jz and 2jz if you have a compete harness,ignitor and ecu,you will just run the harness thru the fire wall plug it in to the ecu and make sure everything on the engine side is plugged in...then go to http://www.apexi-usa.com/manuals/ele...fc2_wiring.pdf i be leave T8-D if the engine came from a 96-01 and T8-C if its 91-95.....find the IGN,ground that will get the ECU fired up and working...After that you need to get fuel to the engine so you jumper your fuel pump to get it flowing....After that you have more wiring i think to make your starter turn with the switch but you can put a push button starter untill you get all the wiring worked out...There is alot more to it but this will get the engine running..
