Thread: engine knockin?
    Aug 2009
    cartersville
    Default engine knockin?
    Whats up ia im havin a problem with my da i turned it on this mornin and it started makin a knockin noise everytime i push on the gas to about 2000 rpms something starts knocking/rattling but it still runs anyy one have an idea of what it could be???
    TheMyth
    If it is a rod knocking , you can pull/replace a spark plug wire 1 at a time to find out which cylinder has the malfunction. When you pull the spark plug wire while the engine is running, you relax the cylinder and the knock will go away. If the knock continues , you could have multiple knocks but you should have heard this in the making before now.
    Sent from my Galaxy Nexus using Tapatalk 2
    It's all about JDM.
    CA to GA
    Chances are, you probably ran the engine dry without checking the oil level and pistons are blown.
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    pistons are blown? can you explain this?
    98 Acura Integra LS-DD
    ??????????????????-project
    lol pistons are blown. Thats funny.
    ROD KNOCK is because most likely the rod bearings have spun, due to oil starvation or age, and the noise you are hearing is the rod "knocking" against the crank. Usually if you can hear it, its too late, the crank and rod(S) are trash.
    What you need to do is check the oil asap. See where the level is .
    Next you need to drain the oil if it has some and look for metal shavings. Use a magnetic oil plug, or strainer and see if there are metal shavings.
    If the knocking is RPM based meaning it gets louder or worse as you rev the engine, its most likely a rod. It can be other things for sure.
    While it does sound like a rod knock from your description, i have heard water pumps or loose timing belts make a similar noise (tough to say without hearing it myself). But like mr.kidd said, if its a rod knock your rods/crank are already toast and may have dumped metal shavings throughout the engine already.
    Columbus GA
    Sometimes you can get lucky with ATF. I've seen a few cars get ran low on oil to the point of knocking, topped it off with some ATF and it went away.
    Then drain it and oil change with a hefty amount of lucas. Had pretty good results doin that in old tired yard/work trucks.
    Privateer Racing!!
    Duluth,Ga
    Who's there?
    Quote Originally Posted by B18c1Turboed View Post
    Who's there?
    No more rod bearing, but if you put in ATF you dont need bearings apparently.
