Thread: fuel pump issue
    i like hubcaps madwick's Avatar
    Dallas
    Default fuel pump issue
    1990 honda civic wagon D15B1 automatic 2wd
    replaced the main relay and fuel pump
    i do not have any power to the fuel pump. i connected a jumper from the ignition wire from the radio harness to the (solid yellow, white stripe, single red dot) wire at the connector before the fuel pump. the fuel pump continues to pump but does not turn off. i am able to get the engine started but i cant seem to figure out why i dont get power. any advice?
    checked fuses?
    Dallas
    yeah i couldn't find any bad. i started trying to trace the yellow wire back to the fuse panel under the dash but couldn't find it. when i lowered the fuse panel, the seat belts stopped working. something serious has happened and i think there is a short somewhere. i just cant find it and i must be looking in the wrong locations!
    Dallas
    very helpful info, thanks. i haven't had a chance to play with the car yet but i will post my findings.
    Northwest Georgia
    haha i would just move whatever wire you used for powering it testing it to a spot where it gets power with key on only and forget it.
