Thread: System no power?
    Apr 2011
    Default System no power?
    My system suddenly went out on me 10" sub and amp checked fuses/cables/grd/+. Nothing so I took it out and plugged it directly to battery +/- no amp to amp.
    I tried my friends system directly to battery +\- still nothing power is anything?
    Any ideas?
    IA Member Boosted535i's Avatar
    May 2012
    Norcross
    Have you tried checking the remote wire to make sure its still connected to the back of your head unit?
    Apr 2011
    Yes I even ran a new wire to to check if the old one was damaged.
    May 2012
    Norcross
    Id either try hooking your amp up to someone else's car and if it still doesn't turn on the mosfets could be fried and if you take the cover off your amp it should be clearly visible that its fried.
    Apr 2011
    Thanks Bro I'll check it out!
    May 2012
    Norcross
    No problem bro hoping thatll answer your question if not let me know and i can help you trouble shoot further
    2 low 4 common sense PTCDC5's Avatar
    A multimeter will solve this problem in 5 minutes...much easier than all the back and forth of trying to hook it up in someone else's car.
