Results 1 to 2 of 2
Thread: Lsv piston help
    Nov 2009
    Griffin
    Default Lsv piston help
    Ok well heres my dilema am building an lsv using stock rods itr pistons and arp rod bolts i have checked all clearances everything comes out good iam also using new stock std size bearing i have torqued the main caps to oem spec as i torqued the rod bolts i torqued 4-2 and everything spins like it should but once i torqued rod 1 motor locks up what could be causing this
    The clearances can't be right... Tell us the oil clearances on the rods since you check and said it's ok, and what's the TQ that you put on them? Oil or Asemble lube used?
