Results 1 to 40 of 53
Thread: V8 Exomotive Exocet
    IA MEMBER YokotaS13's Avatar
    saudi arabia
    Default V8 Exomotive Exocet
    So here is the plan.
    1. Strip miata
    2. install exocet chassis
    3. go fast
    Basically this is a direct replacement for thet miata body, onto all the running gear. You can see more info at the website HERE. It drops a third of the weight, with minimal fabrication making it one hell of a gocart. Couple that with my 300hp from the built(ish) 302 and it is a fucking trip. It isnt the norm build here, but still can be of entertainment for you guys. This whole build will take place over the next two-2.5 weeks. I am going to pick up the chassis Saturday, bring it back and do some modifications
    the plans are for this weekend/monday:
    modify the firewall to accept the larger bellhousing of the 302, and for ease of install, removal.
    Fab up the floor pans; Normally they are riveted on aluminum, but i am using 16ga steel, and welding to the frame itself for rigidity and strength.
    Weld in mounts for switch panel, get fuel lines, and buy some brake line
    Next thursday i take the trip up to south carolina to do the actual build (i am in florida right now) saturday ill start the stripping of my miata (some of it is sold already, hopefuilly most of hte extra parts will be by that week) and plan to have the shell ready to be removed sunday afternoon and progress from there. Plan is to be totally done by the following weekend and get the roll cage built to tie into the frame itself instead of how the race version is bolted to parts.
    anyways, less talking, more pictures.
    Miata as it sits:
    Miata front.jpg by Flsimages, on Flickr
    miatafrontside.jpg by Flsimages, on Flickr
    miata top down.jpg by Flsimages, on Flickr
    IMG_1880.jpg by Flsimages, on Flickr
    Then the conversion you see here:
    (from a shoot i did last weekend)
    IMG_2413 by Flsimages, on Flickr
    IMG_2378 by Flsimages, on Flickr
    IMG_2374 by Flsimages, on Flickr
    IMG_2370 by Flsimages, on Flickr
    IMG_2369 by Flsimages, on Flickr
    www.exomotive.com/exocet
    got the rear panels on, the tranny tunnel patch panel sucked to make.
    pics from saturday AND tonight
    IMG_2426 by Flsimages, on Flickr
    IMG_2430 by Flsimages, on Flickr
    welds are perfect, but im still relatively new to welding large amounts, so it is improving alot
    IMG_2438 by Flsimages, on Flickr
    IMG_2443 by Flsimages, on Flickr
    IMG_2534 by Flsimages, on Flickr
    IMG_2535 by Flsimages, on Flickr
    flash makes it look a little worse than it looks on the backside
    im at a stopping point. need to mock up the engine/tranny combo to build out the trans tunnel and then skin everything. I will be welding in everything except the top of the trans tunnel (going to make a frame from the same 1" bar that the frame itself is made out of) and then i will be bolting hte top in (with nutserts under) to facilitate about a 15 minute engine/tranny removal process.
    awesome build so far! Welds look great, but it's hard to mess up with a MIG.
    saudi arabia
    nah, its pretty easy. i have some ugly parts to prove it
    IA Member mixed_body's Avatar
    law'ville, GA
    I seen this on S|W im 244brick on there.. But i'm watching this closely
    Cleftlowbooty
    -Accord wagon -
    Johns Creek
    I would love to have an Exocet.
    saudi arabia
    do it! they are relatively cheap
    Johns Creek
    All money goes to wife, kids, and house - keeps me from projects like this.
    saudi arabia
    then y on a car forum?
    shouldnt you be on a have no fun with autos forum?
    Quote Originally Posted by YokotaS13 View Post
    Yeah the guys over on domesticatedatlanta.com are a breed of their own.
    Kennesaw, GA
    I've been waiting to see someone do a v8 swap with one of these.
    For the price of the shell, I don't know why I haven't done is yet. This is so cool!
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    Johns Creek
    I still have toys, and have had them since before most on here could even drive. I have cars still now, not just domestics.
    I'll build more toys in the future, just not this year.
    Johns Creek
    I've been on IA since close to the beginning, and was building imports before you got behind the wheel.
    saudi arabia
    :golf clap:
    Johns Creek
    YokotaS13, I'm pretty sure that you are familiar with the FF Type65. That's my long term goal for my Mustang. My next step is a new built bottom end, upgrade the fuel supply (again), and upgrade the supercharger. I'm staying with a 8.2 deck build, just need a forged Dart/FRPP block.
    You should add a supercharger on your 302. A Si-trim could get you to 450-500rwhp with your stock block, without pushing it too much. That should have you beat most cars that you will find on the road.
    saudi arabia
    with 1550-1600 lbs. i will already beat most cars on the road except highly modified ones.
    Ferarris wont be a problem from a roll (from a dig due to traction i wont obviously), Most corvettes with mild mods. etc .
    I want to put a roots SC on it, but i want to stay Carbed as well, unless there is an easy way to do EFI with my harness. if i can make 350tq to the wheels, id be elated. but it needs to still spin to 7.5k like mine does. (Forged internals, balanced crank and rotating assy, stock compression, ported heads, titanium valve seats and retainers, oversized valves from a diff head, double valve springs, shaved heads, edelbrock cam, holly IM, edelbrock carb, 6al, street blaster coil, msd distro)
    Im more worried about a good TQ curve than HP however. dont really care for the other way around. i still want to race this car. plan on a few time attack events next spring once everything is perfect
    as for hte FF stuff. if you have the money go for it
    i cant justify it. but this kit is cheap enough it is still stupid fun and simple for anyone to make
    Johns Creek
    Roots SC's tend to be too much too early on, making traction more difficult on light cars. They are also heavy with the heat. Centri's are a little slower on initial power delivery, and easier to cool the charge. Just a suggestion. You should talk to Bob at Kurgan Motorsports, up by Road Atlanta. He knows everythign there is about 302's.
    I have a friend with a turbo Miata. Maybe he will do an Exocet.
    saudi arabia
    if i hadnt blown up my turbo engine i would have just done that. but the exocet wasnt available then.
    And i want that hard initial tq. then i dont have to clutch kick haha.
    When i drift, ill love it
    when i track it. ill be on slicks anyways, so i dont really care, coupled with an aero package im working on (splitter, diffuser, and wing) should be able to maintain traction into and out of turns
    saudi arabia
    so 4 cans of rust prevention spray paint isnt enough. i need another 3 to finish - _ -
    saudi arabia
    prolly doing these wheels also
    Luxury abstract Madors in a 16x9 step lip -20 or so offset
    Johns Creek
    Aren't those a little heavy for this project?
    saudi arabia
    not really. forged 3 piece wheels. be just as heavy as a set of works
    saudi arabia
    Ok. did some work today!
    stripping the miata by Flsimages, on Flickr
    aero! by Flsimages, on Flickr
    stripping miata by Flsimages, on Flickr
    Wiring harness is out. engine is disconnected and all that jazz. Just have to drain the transmission and coolant so i can pull the radiator and driveshaft. at that point, i can pull the body off so we are right on the plan to pull the body by sunday
    also fitted some parts. Test fit the brake master, and fully fitted the clutch pedal and master cylinder (note, it is different than yours, i have mine powering a hydraulic conversion on a ford t-5 transmission)
    fitment issue by Flsimages, on Flickr
    dodgy fitment of clutch pedal. had to open all the holes up, including the main one (main one was due to diameter of the clutch master)
    clutch master mounting by Flsimages, on Flickr
    Clutch master mounting by Flsimages, on Flickr
    still have to lop off the extra threads.
    other than that, pretty mild day. most of it was spent running around getting some supplies, and unloading the trailer with tons of stuff, so i only did about 5 hours of work total id say. by lunchtime tomorrow the body should be off chassis
    saudi arabia
    So update.
    busy busy day, wish i could have been there at the event today
    Last Import-2 by Flsimages, on Flickr
    Last Import-1 by Flsimages, on Flickr
    Last Import-3 by Flsimages, on Flickr
    Last Import-4 by Flsimages, on Flickr
    Last Import-5 by Flsimages, on Flickr
    Last Import-7 by Flsimages, on Flickr
    Last Import-8 by Flsimages, on Flickr
    Last Import-9 by Flsimages, on Flickr
    Last Import-10 by Flsimages, on Flickr
    Last Import-11 by Flsimages, on Flickr
    Last Import-12 by Flsimages, on Flickr
    Last Import-13 by Flsimages, on Flickr
    Last Import-14 by Flsimages, on Flickr
    somewhere, GA
    This is gonna be awesome!
    '82 TE72 SR5 Sport Coupe
    3tc
    saudi arabia
    and a lil more work before i was done. stripped the subframe. found a bent LCA to knuckle bolt on both sides.
    Last Import-0 by Flsimages, on Flickr
    getting bushings pressed out tomorrow
    and done
    saudi arabia
    got more stuffs done
    subframe is totally stripped and going ot Powdercoater in the morning for a nice bright color.
    Frame is now in the garage, and the engine/subframe are installed. trans mount is mocked up so i can build out the trans tunnel. getting some welding gas tomorrow, so life will be easier
    Last Import-6 by Flsimages, on Flickr
    saudi arabia
    and more
    saudi arabia
    So, now that i had the pedals mounted, i could build a firewall around them
    I also moved the gas and brake pedal over an inch each (cut and welded on a piece of 1/8th steel to space it over) which you will see tomorrow when i put it all back in.
    anyways, today i reframed the firewall to how i wanted it. the bellhousing is much wider than i anticipated so it is going to be WAY tight hence the push over on the pedal. I also framed out a transmission tunnel since i dont want to just bend it. I want to be able to remove the top panel, and pull the engine that way so it can come out much faster. I pull my engine quite frequently to do head removals, to check pistons and other things since i run it at such high RPMs constantly (7500-8k) so ease of maintenance was very important.
    More on this. You see the panel isnt quite "bent" like the rest. When i put in this patch panel, the bellhousing bolt is actually only a fraction of an inch from the panel as it sits now, so i wouldnt be able to facilitate a bend to be uniform.
    inside shot showing how i reframed it
    i apologize for the unground welds, and ugly stuff. i was letting my dad learn how to weld lol.
    here you can see the trans tunnel i framed out. There will also be a panel bolted to the main cross bar, going to the tunnel (also mounted on bolt tabs) to hold the switches , circuit breakers and relays, (on the backside)
    and here is what it looks like as i put her to bed
    somewhere, GA
    coolest project i have seen in a while!
    3tc
    TOYOTA1515
    It is cool and all but i dont like the design of that chassis, the miata looks way better, but please dont take it bad bro u r doing a awesome job and i do apresiate your work cuz it is superb.
    Keep the good work and please make me eat my words and make it prety i know you can!
    SR20 Carbed Datsun B310
    Stay Humble
    WV
    Subscribed
    Stay Humble
    WV
    Are these street legal?
    saudi arabia
    100%
    Go to Exomotive.com
    Kevin is right in your backdoor in roswell where they are sold
    Stay Humble
    WV
    I wonder if you could buy them pre assembled. I'm really interested in these.
    saudi arabia
    He can build it. but its not going to be cheap.
    a guy in ohio is selling his for 25k iirc.
    you can build one under 10k
    No pictures to post. However, the front passenger and rear brakelines have been bent and mounted via Pclips and nutserts. i trimmed my engine mounts to lower the engine 2 inches in the engine bay since i wont have this car as low as i used to and wont be breaking road reflectors. The front subframe is now reconnected and struts connected.
    I am picking up my rear subframe from powdercoat (royal blue with flake overlay), hte new diff carrier is here, both new rear lower control arm bolts, and front brake lines (i tore mine from too much steering angle and stock mounting locations.
    tomorrow i have to grab some bolts, posterboard and then its time to tackle the upper firewall, and ill start mounting/running wireharness, starter relay, fuel pressure regulator, etc etc
    Read more: http://www.mevowners.proboards.com/i...#ixzz1vvsJRfjE
    I'm not an engineer but why would the tubes be above the square tubing at the front?
    I'd just assume it would be stronger in the event of an impact mounted behind? Just curious, not sure if more is added down the road or what.
    saudi arabia
    can you point an arrow for me please? not sure im following and want to be sure that i answer correctly
    Yeah, sorry:
    Attached Thumbnails Attached Thumbnails -123-jpg
    Are you going to really keep that forward facing exhaust?
    2009 GT500 Vert
    saudi arabia
    Not 100% sure. I imagine it is so the radiator can be mounted correctly?
    i really cant give a 100% answer on that one.
    could be just deisgn of bodywork related also
