Thread: What HIDs should i get on my honda civic si 2012?
    Default What HIDs should i get on my honda civic si 2012?
    I wanted to see what HIDs should I get on my car? Also what fogs. I wanted to see what would be the best color and everything but i also dont wanna be pulled over. I have a black sedan si. Also, I wanted to see where I could buy them and get them put in? thanks for all the help
    unknown
    8k/10k on headlight and yellow fogs
    It depends on what you're looking for by "best color".
    If you want to have HID lights for increased visibility (performance), stick with 3,000k-4,300k which has the highest lumen output.
    If you want it for color (or looks), you can go with higher temperatures but the lumen output (visibility) will be sacrificed the higher the temperature.
    Depending on your level of mechanical skill, you may be able to install the kit yourself. If you buy it local, they should be able to install it for you for a fee.
    Aaron
    McDonough
    I use nothing more than 6K due to the above mentioned issue with visibility. I would not go with a "color" for headlights and for fucks sake no HID lighting in the foglights.
    Bitches love bacon.
    2 low 4 common sense PTCDC5's Avatar
    If you don't have projectors or do a retrofit then no HIDs is the answer.
    Quote Originally Posted by PTCDC5 View Post
    Preach it! No H.I.D.s, damn right.
    Quote Originally Posted by hondacivic7 View Post
    I'll buy and install them for you. $100 flat, i'll come to you if you're within an hour of atlanta. PM me.
    I just finished my retrofit
    Apr 2012
    Cartersville
    If you can't install them, get rid of your car. I can't fix barely anything, and I can install them lol.
Tags for this Thread
