Results 1 to 4 of 4
Thread: Good Suspension Setup?
    BarnDog296 BarnDog296's Avatar
    Clairmont
    Default Good Suspension Setup?
    I am replacing my stock suspension (amazingly it is still original equipment - 160,000 miles!)
    I was wondering if the setup I am planning on buying is a good setup? Its for a S13 HB
    The Plan is to get KYB AGX shocks and struts, with Tein S-Tech Springs. It will drop the car about 1.5" (not enough to get camber adjustments) I am also wondering if I am doing the install myself, is there anything else I should get before I get in there and start finding all kinds of problems? For instance, would it be beneficial to get a full new set of bushings?
    IA's Transformer God obd1kenobi's Avatar
    29th Chamber
    Mos Def get the bushing, Check the tie-rods, they may be bad! Other than that, Maybe the strut mounts but thats all.
    GeckoSquad / Skull Platoon
    Stan The Man TallGuy's Avatar
    Dacula Ga.
    Koni yellows and Ground control slipovers, by far the best suspension iv ever had....IMO
    Jan 2003
    Quote Originally Posted by TallGuy
    If you don't mind cutting the strut housing and inserting the KONI inserts, plus the rears are not externally adjustable on the 240sx, boo to KONI for otherwise great shocks.
    I'd suggest getting the RSR down springs rather than the Tein Stechs... I tihnk they're a little more stiff and lower the car a little less.
    After that, get subframe spacers/bushings, and you'll be set.
