Thread: FS/FT: 1995 S14 Widebody Midnight Purple $8000
    is better than you..
    Somewhere you're not
    Default FS/FT: 1995 S14 Widebody Midnight Purple $8000
    1995 Nissan 240sx
    5 Speed
    Stock KA24DE w/ Bolt Ons
    200k+ Miles on the chassis (did not get a cluster when I got the shell)
    When this car was painted all glass was pulled and reinstalled with new front and rear molding. Paint is about a year old. The overrfenders were bowed to be more then 50mm (to about 60-70mm) and were then molded to the body.
    Mods:
    - Origin Lab Stylish Front Bumper
    - Origin Lab Rear 50mm Over Fenders
    - Origin Lab 20mm Front Fenders
    - Origin Lab Roof Spoiler
    - Version Select Type 1 Sideskirts
    - Version Select Type 1 Rear Bumper
    - Seibon Carbon Fiber Hood (cracked)
    - Shaved third brake light
    - Vertex Headlights
    - DMAX corner lights
    - DMAX bumper lights
    - Kouki S14 Taillights
    - Midnight Purple (LP2) Paint
    - Tein Flex Master Coilovers
    - Megan Racing Rear Upper Control Arms
    - OBX Header
    - OBX Lightweight Pulleys (Crank, PS, Water Pump)
    - Test Pipe
    - 5Zigen Catback Fireball Exhaust
    - Centerforge Clutch
    - Rays Foundry DR505 Wheels 18x10 -0 (-25 front/ -45 rear w/ spacers)
    - Evo Brembo Front Brakes w/ Adapter Brackets
    - Engine Bay Tucked - fuse box relocated to under the front passenger airbag cover on the dash.
    - Sparco Deep Dish Steering Wheel
    - MOMO Long Hub
    - NRG QuickRelease
    CAR DOES NOT COME WITH RECAROS CAR WILL HAVE STOCK S13 SEATS.
    The Bad:
    - Front end was damaged in a <5mph accident and caused the hood to crack and bent the radiator support, The radiator support has already been replace just needs to be painted to match the rest of the bay and tack welded on the ends to the chassis (its current just screwed in) everything else is fixed.
    - KA Burns a little oil (not bad onlly when you get on it)
    - Needs rear subframe bushings
    - An alignment
    - Exhaust Leak at the resonator from bottoming out
    - Needs Sunroof, does not open only tilts does not leak
    - No Wipers
    - Has Heat and all the lines for the AC are there but just needs Recharge, Belt and Pressure switch.
    - Needs 5spd ECU for check engine light to go away.
    - No Radio
    Asking
    $8000 OBO WITHOUT WHEELS
    $10500 FIRM WITH WHEELS
    I WILL ENTERTAIN TRADE OFFERS BUT I DO NOT WANT ANOTHER 240SX UNLESS ITS RHD, NOR DO I WANT YOUR CIVIC OR INTEGRA. DONT WASTE MY TIME
