Results 1 to 3 of 3
Thread: ball joint nut help
    Jul 2010
    Default ball joint nut help
    hey everyone i took out the disk arm to reaplce a new one and now the lower and upper ball joint nut giving me issue...first i try to use the bolt to bolt back in the nut but the nut keep on spinning with the bolt and cant close it. any advice would help i try to use a plier to hold the nut and it works a little but the plier is still in the way where i cant close it.
    winder
    are you using a air gun?
    Always helps to load the suspn, but if the ball joint moves that freely then it needs replaced anyways!!
