Results 1 to 4 of 4
Thread: FS: GSR B18C1 block, crank, etc.
    Wanting Boost! rsxappeal's Avatar
    Default FS: GSR B18C1 block, crank, etc.
    Hey IA,
    I planned on building this GSR but ran out of funds. I already had Scott's machine shop check out the block. I paid them $125 to have the block cleaned/inspected. They have to do that before they do any work to the blocks. I ended up picking up the block and bring it back to my house because I didn't know which size pistons I was going to use. The block has been sitting in my garage ever since. It is stock bore, ready for you to do whatever you like!
    I have the matching main caps, girdle, etc. (A must have when buying a used block!) I have the waterpump too, but you might as well replace that when rebuilding. Also have the lower timing cover, waterneck, etc. The machine shop took off all of the plugs, oil squirter, etc and put them in a box for me before they cleaned it. Asking $250 for the block and everything listed above...
    B18C1
    Block Code: 1303846
    I also have the matching GSR crankshaft. It is in good condition. No spun bearings, etc. I had the machine shop check it out too when I was up there with the block. Ready to go. No refinishing needed... Asking $100 for the crankshaft
    Call or text Brian 770-468-2937
    Now for the pictures:
