Results 1 to 2 of 2
Thread: Asus F1A75-M LE Mobo.
    Certified Gearhead oreign's Avatar
    May 2011
    Default Asus F1A75-M LE Mobo.
    brand new still in box, untouched. 67832075O6
    $70
    specs:
    ASUS
    Model
    F1A75-M LE
    Supported CPU
    CPU Socket Type
    FM1
    CPU Type
    A4 / A6 / A8 / E2 APU
    Chipsets
    North Bridge
    AMD A75 (Hudson D3)
    Memory
    Number of Memory Slots
    2×240pin
    Memory Standard
    DDR3 1866 / 1600 / 1333 / 1066
    Maximum Memory Supported
    32GB
    Channel Supported
    Dual Channel
    Expansion Slots
    PCI Express 2.0 x16
    2 (x16, x4)
    PCI Express x1
    1
    PCI Slots
    1
    Storage Devices
    SATA 6Gb/s
    6 x SATA 6Gb/s
    SATA RAID
    0/1/10/JBOD
    Onboard Video
    Onboard Video Chipset
    None
    Onboard Audio
    Audio Chipset
    Realtek ALC887
    Audio Channels
    8 Channels
    Onboard LAN
    LAN Chipset
    Realtek 8111E
    Max LAN Speed
    10/100/1000Mbps
    Rear Panel Ports
    PS/2
    2
    Video Ports
    D-Sub + DVI
    USB 1.1/2.0
    4 x USB 2.0
    USB 3.0
    2 x USB 3.0
    S/PDIF Out
    1 x Optical
    Audio Ports
    3 Ports
    Internal I/O Connectors
    Onboard USB
    2 x USB 3.0 + 6 x USB 2.0
    Other Connectors
    1 x COM port(s) connector(s)
    1 x CPU Fan connector(s)
    1 x Chassis Fan connector(s)
    1 x Power Fan connector(s)
    1 x S/PDIF out header(s)
    1 x 24-pin EATX Power connector(s)
    1 x 4-pin ATX 12V Power connector(s)
    1 x parallel port connector(s)
    1 x Front panel connector(s)
    1 x Front panel audio connector(s) (AAFP)
    1 x Internal speaker connector(s)
    Physical Spec
    Form Factor
    Micro ATX
    Dimensions
    9.6" x 9"
    Power Pin
    24 Pin
    Features
    Features
    UEFI BIOS - EZ Mode - Flexible & Easy BIOS Interface
    AI Suite II - One-stop Access to Innovative ASUS Features
    USB 3.0 & SATA 6Gb/s Support - Double Access, Double Convenience
    Multi-GPU CrossFireX Support!
    May 2011
    bump with specs
