Thread: 1999 civic lowering problem
    Mar 2012
    conyers
    Default 1999 civic lowering problem
    I have a 1999 Honda civic ex. I just put in a eibach lowering kit. I had no problems with the install. but soon after I started hearing noise from the right rear. I took that one back apart. adjusted it because the spring wasn't all the way butted up against the strut plate. I put it back together and heard no noise for about a week. now I am hearing it again. any ideas what this could be or advice to fix it. please I need help. its just odd that only one out of four makes noise.
    Aug 2010
    DeKalb county
    when does it make noise and what type of noise do you hear?
    Mar 2012
    conyers
    Its when I drive over rough spots in the road and its like a clunking noise.
    Aug 2010
    DeKalb county
    the spring is not seated on the strut plate properly
    Apr 2011
    does it sounds like it hitting the top of the strut tower? did you use bump stops?
    Mar 2012
    conyers
    I have already taken it off and reseated it. I will check it again and let ya'll know. And yes I did use bump stops on all four
