Results 1 to 17 of 17
Thread: '78 Datsun 620
    Middle, Ga
    Default '78 Datsun 620
    Picked it up cheap.
    Body is in good shape, needs paint.
    Already have some fender mirrors just need to put 'em on.
    It has already been lowered but needs moar loooooowwww!!!
    I have been trying to do some homework on the lowering procedures on these old trucks. Found a couple good builds simliar to where I want this one to be. In a nut shell, I want to get this things as low as it will go without bags or any crazy modifications. Like it or not, its mine! Cheap paint, minor body work, crazy offset diamonds, and alittle interior touch up basically is all I have on the list. Any "good/helpful/friendly" adivce, sling it my way. Wanna hate, just hit the red X at the right top corner.
    Weber carb, new VC gasket, plugs, wires, and dizzy cap. Runs pretty good and clutch feels decent.
    Inspiration!!!^^
    "Damn, Its Tyler"
    RaceReadyDevelopments
    Super Certified metalmatt47's Avatar
    Jun 2010
    Powder Springs, Georgia, United States
    Nice bulletside man. What part of GA are you in? Were setting up a 620 crew locally. Got 3 trucs together so far.
    Conformity is the jailer of freedom and the enemy of growth.
    - John F. Kennedy
    Jun 2010
    BTW, For lowering the front, cut the bumpstops down and back out the torsion bars all the way. If you want lower, you can pull them out and rotate them (re-index) them a notch to give you more room to drop it.
    For the rear, get a set of leafs off of a 4x4 720 pickup and that will drop you another 2 inches. The arch on the 720 springs is much less aggressive then the 620's.
    - John F. Kennedy
    Middle, Ga
    If you look VERY closely on the passenger door at the bottom corner by the front fender you can see a TINY small rust hole. Only patch of rust on the body I've found. Undercarriage is rust free along with the rocker panels and inside cab. The battery tray is rusted tho.
    I have alot of small things I wanna try so stayed tune!
    "Damn, Its Tyler"
    Middle, Ga
    Quote Originally Posted by metalmatt47 View Post
    Thanks man. I stay down here in Macon. Once I get this looking decent I wouldnt mind meeting up sometimes tho. Right now, its horrible. haha.
    "Damn, Its Tyler"
    Actually, if you'd like to go as low as you can, just remove all the helper springs from the rear and flip the lone spring left. This is what I did on my '77 Toyota. Later, QD.
    "JAY" Spec Jay12know's Avatar
    First off I just want to say GREAT find man...I've been looking for a Datsun 620 for a long time now and still looking daily! If you come across anothr one or ever try to sell this one
    PLEASE let me know!
    Middle, Ga
    You wouldnt happen to have a picture of your 77 would you?
    "Damn, Its Tyler"
    Macon, GA
    check out infamousnissan.com there are a couple 620s over there mostly 720 and d21s but plenty of info and people who know what they are talking about.
    Middle, Ga
    This is what I want to acheive as far as lowering wise.
    "Damn, Its Tyler"
    Quote Originally Posted by FasTech View Post
    Not a good one, though. This picture was taken back in 1992. Later, QD.
    Middle, Ga
    What did you do about the front?
    "Damn, Its Tyler"
    The front end of this truck had coil springs. Not torsion bars like I think yours does. From my understanding, you should just be able to crank down on the nut on the end of the torsion bar to lower it. Later, QD.
    Middle, Ga
    Yes, I have torsion bars but they will only go so low I am sure. Guess we'll find out soon enough. Now when you were explaining about removing all helper springs, you mean take all the leaf springs but one? Kinda confused. Because I chatted with a guy at IA and he said he removed every leafspring but one and flipped it on his to slam it.
    "Damn, Its Tyler"
    Yes. There is only one leaf that bolts to the front/rear shackle. Remove all springs but that one, turn that one upside down and place it back in the shackle and bolt it back in. You'll need help and another car jack. One side will be easy to bolt up. You'll need the car jack to raise the unbolted side into position as you won't be able to push it up at all. Later, QD.
    Middle, Ga
    Thanks for the instruction, Qd.
    "Damn, Its Tyler"
    Sep 2012
    Roswell GA
    seee i like his front light being round and shit <3 shits sexy but my car doesnt fit round lights=(
