Thread: OK who had a megasquirt with a 2jzGE running the stock dizzy?
    TOYOTA1515
    Default OK who had a megasquirt with a 2jzGE running the stock dizzy?
    where did you get the base map for your MSII to start the car up and start tunning it?
    SR20 Carbed Datsun B310
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    Found this, but I'm sure you already found it too: http://forum.clubna-t.com/showthread.php?t=5507
    I'd shoot the guy a PM maybe he'd send you the map and you can burn it to your chip
    TOYOTA1515
    Yes i did find that one too a few weeks ago, the EMS is already installed i just need a base map to download to the ECU to start this biotch LOL,
    Hope the guy answer cuz Dynotec wants to charge 10 Hrs to built a base map from scratch uffffff!
    Sep 2011
    try diyautotune.com they are up in suwanee
    Christina- (97 EK) - Project Boost
    Kandace (95 DC) - Project All Motor
    TOYOTA1515
    They dont have shit, after i tell my customer to buy the EMS from them basically they told me i need to do a base map from scratch to start the car, and that pissed off my customer cuz now he has to pay a tunner to do so and what's supposed to be a cheap EMS is going up to about $1800 if i knew that beforehand i will tell him to buy a haltech or a microtech and the car would be running months ago!
    hope this isn't the batmobile we're talking about
    http://www.youtube.com/watch?v=dTbrupBKxpo <<The dude who posted that vid was active last month so he's still around, Might be worth it to shoot him a message, maybe he's down to send over his .msq file
    Maybe you can just get it to idle since you're doing a fuel only setup using this http://www.ajdesigner.com/phpengine/...efficiency.php (assuming that's the case since you're using stock dizzy setup)
    Here's some info that someone posted about a naturally aspirated 2J motor, I assume it shouldn't be too different, though I know the GTE head flows better: http://thedeltaecho.wordpress.com/20...ic-efficiency/ Should at least be enough info to get it started.
    Does the car have a wideband o2 sensor? You can probably just tinker with it once you get it to idle until it's good enough to call a "basemap"- haha. Probably not a good idea if you're breaking in the motor though- I've heard, it's arguable though.
    http://www.diyautotune.com/tech_arti...squirt_ems.htm
    TOYOTA1515
    No is not the batmobile,
    Unknown
    Apr 2009
    Hello Dragoncelica,
    We don't have a complete tune (as in something we've run on a dyno and gotten completely dialed in, and can personally vouch for) for one of these, but I can go over individual settings. (Was this the 2JZ being run on alcohol, BTW? I seem to recall it was a bit of an unusual build.) The pre-VVT 2JZs used a fairly common trigger setup used on a lot of Toyota and Mazda applications, described here in the manual:
    http://www.msextra.com/doc/ms3/trigg...el.html#nippon
    The exact setting for the #1 tooth angle can depend on how the distributor is installed, but the link I've sent gives a procedure for how to adjust it. You'll need to use a timing light to make the final adjustments.
    Generally, an MS3 with the normal base map would need these things set up:
    - Ignition
    - Number of cylinders
    - Injector size and engine displacement (Required Fuel)
    - Idle valve type
    Once these have been set, it should be FAIRLY close to starting up on the off the shelf settings. It probably won't run great and will need its fuel and ignition tables tuned to match what the engines should need, but setting these will get you close.
