Results 1 to 10 of 10
Thread: F22b1 Help (Oil leak, Timing Belt, Parts)
    Certified Gearhead Potter's Avatar
    Oct 2009
    Southside
    Default F22b1 Help (Oil leak, Timing Belt, Parts)
    Im going to have the crankshaft seal on my 94 accord replaced due to an oil leak. The timing belt and water pump will also be replaced. What other seals can I replace that can also be the cause of the oil leak? The leak comes from the driver side of the motor near the timing belt cover and drips near the oil pan. Another question I have is, where can I buy the timing belt, water pump and the seals at a reasonable price? Honda Dealership, or can i rely on somewhere else that has good quality parts? Part numbers will be greatly appreciated.
    LAWRENCEVILLE
    camseal also.
    Hella stock member!
    I personally buy timing belts at dealership, everything else should be okay from autozone/napa/etc.
    I'd go ahead and replace the valve cover gasket. and if you're pulling everything off that side of the motor, go ahead and replace the oil pump gasket, if not the pump. I have an intake manifold and a complete wiring harness for an F22b1, if you're interested.
    Oct 2009
    Southside
    Reps to all you guys for the help.
    @Drummerboy no thanks on the parts but if I need them anytime, i will let you know.
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    Oil pump seal leaks ALOT in that model. Balance shaft seal too.
    98 Acura Integra LS-DD
    ??????????????????-project
    TALKING ROCK, GA
    Quote Originally Posted by Potter View Post
    Im pretty sure he was just showing you where to get the parts, as you asked where to get them at a reasonable price in your original post...
    GWINNETT IS GREAT!
    drummerboy is a G!
    Oct 2009
    Southside
    Quote Originally Posted by hondaxpurt View Post
    and I was saying that I didn't need the intake mani or wire harness at the time.....?
    sounds good man!
    drummerboy is a G!
    I don't mean to toot my own horn, but toot toot!
