Results 1 to 3 of 3
Thread: SR20 GT2860RS oil drip / gasket question
    my turbo is bigger! revsk8erdude's Avatar
    Blairsville
    Default SR20 GT2860RS oil drip / gasket question
    93 240sx with a sr20 blacktop swap. turbo is a garrett gt2860rs and is dripping oil somewhere. pulled off the lower oil return line going from the bottom of the turbo back to the block and saw this \/
    shouldent there be more of a gasket than this?
    I cant track down whats causing the oil drip so i am going to replace the factory bent metal oil feed/return lines with braided stainless steel hoses.
    could anyone tell me what size hoses i need and what the correct sizes/trims are for the gasket i need to order?
    WTB: My own forum, so I can badmouth IA.
    Yes theres a gasket that goes between the turbo and the outlet flange. its usually a thin paperish gasket.
    IDK what the line sizes are, i've used the ISIS oil line kits in the past with no problems on my SRs.
    http://www.enjukuracing.com/products...om-Mount-.html
    You can see the gasket in this pic:
    http://www.enjukuracing.com/products...in-Flange.html
    That drain flange has no real advantage over your stock one though.
    Blairsville
    I appreciate it, I ordered a gasket from Z1, hopefully it will get here relitaviy soon.
