Results 1 to 14 of 14
Thread: FS: Crower 403 VTEC cams
    The names "Skeezy1" Samhonda95's Avatar
    South Ga. (Pelham)
    Default FS: Crower 403 VTEC cams
    Pretty simple.....crower 403 vtec cams unknown miles
    $225 shipped
    text anytime for pics 229-328-3five9one
    South Ga. (Pelham)
    just some more info
    Brand Crower
    Manufacturer's Part Number 63403-2
    Part Type Camshafts
    Product Line Crower Performance Level 3 Camshafts
    Summit Racing Part Number CRO-63403-2
    Cam Style Mechanical roller follower
    Basic Operating RPM Range 1,200-9,750
    Intake Duration at 050 inch Lift 263
    Exhaust Duration at 050 inch Lift 255
    Duration at 050 inch Lift 263 int./255 exh.
    Advertised Intake Duration 305
    Advertised Exhaust Duration 305
    Advertised Duration 305 int./305 exh.
    Intake Valve Lift with Factory Rocker Arm Ratio 0.468 in.
    Exhaust Valve Lift with Factory Rocker Arm Ratio 0.468 in.
    Valve Lift with Factory Rocker Arm Ratio 0.468 int./0.468 exh.
    Computer-Controlled Compatible No
    Valve Springs Required Yes
    Where Am I
    Oh I want lol!!!
    Jan 2012
    Wow. Similar specs to the skunk 2 pro 2 with higher intake duration. These probably need a high comp engine right?
    South Ga. (Pelham)
    I've used the in b16s and just took them out my poor mans r and worked great in both.
    Get'em Turbodude!!!!!
    Jan 2012
    numberS?
    South Ga. (Pelham)
    Quote Originally Posted by phee128 View Post
    numberS?
    what?
    South Ga. (Pelham)
    up
    Jan 2012
    Did you dyno?
    South Ga. (Pelham)
    Did you dyno?
    I had same cams (not these exact ones) in my old motor (gsr) and made 206whp
    South Ga. (Pelham)
    Up
    South Ga. (Pelham)
    still got'em
    Turbo City USA
    pics?
    South Ga. (Pelham)
    Quote Originally Posted by OG-Skinny View Post
    pics?
    pm me ur number and ill send u more
