Thread: 2000 Audi S4 - ASP Stage 3 - Black w/ Sport Interior - Atlanta, Georgia
    Default 2000 Audi S4 - ASP Stage 3 - Black w/ Sport Interior - Atlanta, Georgia
    <b>Listed at $14,000 o.b.o. - not interested in trades.
    Clean Title in Hand
    Serious inquiries can be sent to me at: [email protected] </b>
    The time has come to move on from my S4. I have owned an S4 since 2005, and when my first was destroyed by someone running a redlight I knew I had to have another. I purchased this Stage 3 almost two and a half years ago from a local Audiworld/Quattroworld member that had owned it since new. Between the two of us the entire history of the car is well known. There has been no expense spared while building this car and an incredible amount of time has be spent researching in order to <b>tastefully mod and maintain</b> the Twin Turbo S4. All the work has been done by either the original owner or myself. I have tons of receipts(more than I care to add up). This is a Georgia car - zero corrosion, no salt no sand.
    <i>Simply put this is the one you have been looking for.</I>
    Basic Info:
    2000 6-Speed ASP Stage III ~ 420 whp/420 wtq - @ 25k stage 3 (Full Timing Belt Job Done at that time)
    Black with Black/Silver Sport Interior
    104k miles
    NON-Smoker
    Located in Atlanta, GA within 20 minutes of Hartsfield Jackson Airport
    Interior: 8.5/10 - No rips/tears/burns or excessive wear. Everything works. Cluster has zero missing pixels
    Exterior: 8.0/10 - Always cared for with Adams. Items noted below in photographs to show general paint condition
    General Modification List: (please ask if you feel I may have missed something)
    Aftermarket parts on the car:
    1. ASP Stage 3 kit (K04 turbos, injectors, MAF, software)
    2. AWE intercoolers
    3. AWE exhaust headers (No cracks)
    4. AWE lightweight flywheel
    5. SPEC Disc/RS4 Pressure Plate - hybrid clutch (Does not slip)
    6. ASP 3" downpipes
    7. MTM exhaust
    8. Stoptech 332mm front brakes (extra set of rotors and matched track pads)
    9. UUC driveline stabilizer
    10. UUC short shifter
    11. Stasis Tracksport coilovers (750F/650R) with adjustable rebound
    12. Neuspeed rear sway bar
    13. SSR Competition 17x8.5 with Dunlop Direzza Z1 Star Spec 245/40-17 tires, 50% wear (included in sales price - or select other wheel options below.)
    14. APR snub mount - after careful inspection I see this needs to be replaced
    15. APR Bi-Pipe
    16. SAMCO Hose Kit
    17. 35% window tint
    18. Odyssey PC925 lightweight batter
    19. Stern adjustable camber/caster arms
    20. S8 rear rotors and caliper brackets/adapters
    21. Rear-biased center differential (Stasis)
    22. Euro headlamp housings (different reflector, white/clear turnsignal cover)
    23. B6 S4 rearview mirror with compass
    24. Non ESP car - custom switch to turn off all traction control
    25. Hardwired for Valentine 1 Radar/Laser Detector
    Aftermarket stereo:
    1. Vifa 5" woofer and Peerless 1" tweeters in front door (stock locations)
    2. Audax 6.5" midbass in rear deck (stock location)
    3. Audio Concepts SV10 10" woofer in rear deck
    4. ADS 840 amplifier (8x40W)
    5. PPI 2360 amplifier (360W) for sub
    6. XM Radio with cassette interface (mounted at dash - have original cupholder)
    7. Stock head unit with Phatbox (HDD music player)
    Extra/uninstalled parts:
    1. Fuel filter
    2. Auxiliary water pump (current one has a very slight leak and you can see some pink crusting from the coolant)
    3. Istook Racing adjustable camber/caster arms
    4. Tie rod ends
    5. New Spec Clutch (pressure plate only)
    6. O2 sensor
    7. spare EGT sensors
    8. Bolt on "dump pipes" with secondary O2 bungs- used once at a dyno day to see what gains were made (@15 HP)
    9. "race" N75 valve
    10. VMR 710 19x8 Gunmetal Wheels (no tires) - available with purchase of vehicle for reduced rate
    11. SSR Comp-H 19x8 Wheels (one bent, but repairable) - available with purchase of vehicle for reduced rate
    12. miscellaneous OEM parts that were replaced by items mentioned above (engine covers, sway bars, etc.)
    Photos: (All images are clickable links for larger photos)
    MY LINKS BELOW ARE NOT SHOWING UP>>>> HERE IS A LINK TO MY FLICKR ACCOUNT WITH THE SAME PHOTOS:
    http://www.flickr.com/photos/71831250@N00/6892983074/
    Certified Gearhead jimjam187's Avatar
    yea how many miles on the car?
    104,xxx miles currently.
    mobil 1 0w-40 every 3,000 miles
    Thanks,
    Attached Thumbnails Attached Thumbnails -mileage-jpg
    B5 S4=problems Reaper's Avatar
    Crossfit
    beautiful S! If you decide to part anything out(wheels especially) PM me I'd be happy to take some things off your hands. GLWS!
    Quote Originally Posted by Reaper View Post
    Thanks... Car was sold within 24 hours.
    I still have both the 17" and 19" SSR wheels for sale.
    17" SSrs have 50% Dunlop Direzza Z1 Star Specs on them. These were my track wheels generally... not show wheels.
    19" SSRs have no tires, and one is bent/damaged.
    Let me know if you're interested in either.
    Crossfit
    About to shoot you a pm
Tags for this Thread
