Results 1 to 33 of 33
Thread: 1997 Civic Cx timeline....(Still in the making)
    2SL0W4U AZN_Pride's Avatar
    Dothan, AL
    Default 1997 Civic Cx timeline....(Still in the making)
    I have gone through a plethora of vehicles over the years. I have owned everything thing from BMW to Toyota's. I refused to get a Civic, or a Honda for that matter due to the stereotype. Alas, I broke down and traded my 06 Suzuki GSXR 600 for a slammed Civic hatch with a B16. Being a complete Honda noob, I was unaware of the problems it had. The exhaust was complete garbage, it has a few wiring issues, and all the cheap routes taken. However, I love the car for what it is.
    ALL UPDATES WILL BE IN THE FIRST POST. THIS IS MY LITTLE BLOG SINCE I AM KEEPING THIS WRONG WHEEL DRIVE THINGAMABOB
    Mods-
    Exterior:
    Spoon style spoiler
    Ebay OEM front lip
    Interior:
    New OEM carpet
    NRG quick release
    NRG Hub
    Nardi 360mm Classic
    Sparco Harness bar
    Corbeau cam lock harnesses
    Bride Rep seats
    S2000 Push start
    Sound:
    Sony CDX-GT660UP
    Ininiti Kappas
    Civic Type R Navigation unit
    Engine management:
    USDM P30 ECU
    Hondata S300
    Innovate MTX-L AFR gauge
    Suspension:
    D2 Coilovers
    PIC bushings
    GSR rear disc brakes (not installed yet)
    Engine:
    B16A2
    PLM T/A header
    Injen short ram
    HKS Hi Power cat-back
    Megan racing resonator
    Spoon Tension wires
    Moroso Oil pan
    Blox TPS sensor
    2012 Summer plans:
    have Hondata S300 installed in the P30-A00
    B16B cam shafts
    Toda Cam gears
    Performer X Intake Manifold
    2013 Plans:
    B18C1 Bottom End
    P30 Pistons
    Clean up the engine bay
    Ported and polished B16 head
    Supertech valvetrain
    Here is Day1.
    Many months later:
    I enjoyed how low it was, but I hated the stance. So after trading the wheels, I raised the car up a few inches and bought a cat back exhaust in the process. The HKS Hi-Power was really hard to find and it sounds great so far. Not too ricey like the Skunk2.
    After months of title issues, I finally got the car under my name. The car isn't driven all that much if any. I will take it out on the weekends but as of now, she sits at home. After I splurged more than usual on family for Christmas, I bought a Seibon carbon fiber OEM hood. There was a dimple on the original hood and was bugging me. I also purchased a front lip (EBAY) and Spoon style spoiler and installed them a few weeks ago.
    Yes I know. I am a pure ricer. I have yet to really touch the engine and suspension. I just bought a load of interior parts such as Bucket seats, harnesses, harness bar, Nardi wheel, NRG hub, NRG quick release. I am going to take my friend's advice and drive it and change what I feel is needed.
    I am pretty sure I will need to rebuild the engine within a year or so. It is smoking when I get on the throttle. I am hoping the new test pipe and the second oxygen sensor installed willhelp the issue. Last guy used and OBD2 harness with only 1 O2 sensor. The new pipe will have an O2 bung so that I may use 2. I am debating on going with a high quality LS-Vtech or keep the B16. I believe the K series is too mainstream and I want to stay away from it. It is a FANTASTIC engine but everyone is going K-series.
    I have also purchased a PIC master bearing set. I know I want to go with an ASR 24mm rear swear bar, but as for as the rest of the suspension, I am a tad ignorant in this area. I have a good idea as to what I want but I want to heavily track the car and go from there if possible. I did purchase a rear disc brake set from a user on Honda-Tech, so I am hoping that will help a little.
    Here is where I am at now. As many of you already know.
    I make very good money for my age. However, I have a crap load of bills thanks to an ex. So money is somewhat tight. I am trying to build up my savings (FINALLY) and keep my account at a specific number. So after a few months, I should be able to save a little more and continue to modify the car in the right direction.
    26 Feb 12.
    Well most of my recent purchase have arrived and the rest will be here early this week. The next few days I will be prepping the car for the installation of the new components. A lot of cleaning is needing to be done! Will be removing those horrid speaker wires.
    03 Mar 12
    (Still waiting on Sparco for some hardware. Also my Nardi wheel should be in soon. The Corbeau harnesses will be in once the bar is installed.)
    After spending 12 hours of fighting a seat, cutting carpet, and raging over hour; I finally made some progress. Here is the result of today's labor.
    I KNOW! I NEED TO VACUUM!
    8 Mar 12
    After work I thought it would be a good time to install my steering wheel and hub. Tis a real Nardi ordered from WekSos.
    11 Mar 12
    I completed the interior and replaced the HKS test pipe with a Megan racing resonator with a new OBX O2 sensor. I have an engine scanner on the way to help me figure what all is causing my CEL to be on. I have also ordered 2 new Timken front wheel bearings and should be doing the rear disc brake conversion next weekend when the Prop valve arrives. I am going to use integra E-brake cables and just cut the rubber grommet. I have some Proseal that I am going to use to cover some unwanted holes to reduce windnoise. Anyone in the Aviation industry can tell you how nasty proseal smells when its not mixed together. Think of rotten eggs.
    24 Mar 12
    Finally finished repainting the valve cover. After that, I drilled some holes in the exhaust flange so it will mate up to my resonator. My USDM P30 ECU arrived in the mail along with a Blox TPS sensor, obd2a-obd1 harness, and my final Timken wheel bearing. My Spoon Tension wires are on the way from Japan and my Hasport axles will be in Tuesday.
    30 Mar 12
    I finished replacing the axles, outer tie rods, and a couple of ball joints. However, my oil pan needs to be replaced due to a drain plug that has torn out the threads and has sheared. I am not going to go through the trouble for a busted and JB welded oil pain. I am going to replace it with a Moroso and new gasket.
    11 Apr 12
    The car is back on the ground. The Oil pan has been replaced and will begin to replace the fuel pump soon. I have quite a bit arriving in the mail this week so I started prepping for the new parts. Here is a sneak peak of what is to come.
    12 APR 12
    I was a tad bored today so I did a mach S2K push start install. I have another Emergency button set on the way to replace the current scratched button panel. The Emergency button will be on the right hand side while the defrost relocated in the glove box. I have no heat or A/C so I won't need it really. Not until Winter rolls around.
    Here are a few pics of it installed in the USDM center console. The final product will be installed in the 96-98 Civic Type R Navigation Console. I will have to do a little wiring for the console to work the way I want but it will only be a total of 8 wires.
    21 Apr 12
    Well a few things came up and I had to move the starter button to a different location. About $5-70 later in electrical supplies, I finally have a new Sony headunit, Ek4 Navigation installed, and the starter button in. I may do a few more wiring solutions in order to get more power to the Sony so that I can get a little better sound.
    Here are some pics take a while ago.
    26 Apr 12
    Here is my next area of focus. I have replaced the radio and a couple of speakers in the car so I believe my interior is done for the most part. So I believe the Engine shall receive some attention next. This on may take a year or 2 to complete.
    12 May 12
    After much work I finally got the Edelbrock performer X intake manifold port matched to the 68mm throttle body. I also installed a new fuel rail while I was at it. I know its pretty much useless as far as adding power is concerned but I had to please the inner ricer inside. I am also in the process of deleting the charcoal canister and its lines. Since I am running an OBD1 ECU, I really don't need or care for it. It is not a daily driver, thus gas mileage does not concern me. I just need to connect the evap lines and it will be done. All that is left is to adjust the ignition timing, due to the replacement of the distributor and add coolant. I am hoping to have a LOT more done next month. Hoping to get a lot of overtime hours in with my new schedule.
    30 Jun 12
    Theses parts are collecting dust at the moment.
    13 Oct 12
    I have been a tad busy so money has not been my friend. I have been slowly buying more parts. Here are my last major purchases.
    08APR13
    Starting a new engine build. Going to use all OEM parts. Going to use a ported and polished PR3 head with a Supertech valve train.
    15APR13
    Got a new part in the mail and I am working on the super riceyness(?) of my Civic. Starting to make this stereotypical.
    25APR13
    Some more parts arrived in the mail. About to order a few more things and possibly finish out my AR-15 as well.
    KNXWLEDGE EssexCounty's Avatar
    South Side
    Looking good.!
    Apr 2011
    Looks great man wish mine was as clean as yours, where did you get your harness bar from?
    Sep 2011
    if you dont mind me asking, did you pick the car off of some kid in the stone mountain area?
    Christina- (97 EK) - Project Boost
    Kandace (95 DC) - Project All Motor
    Dothan, AL
    Quote Originally Posted by Munky View Post
    Not sure where he was from. It may have been from Stone Mountain. Why?
    Dothan, AL
    Did a little work today. Not a whole lot.
    McDonough
    I like where this is headed.
    Bitches love bacon.
    Dothan, AL
    12 APR 12
    Dothan, AL
    21 Apr 12
    Senior Member C230K's Avatar
    Feb 2012
    Idk you tell me
    Where did you get that navigation system? That shits badass, even the push start NICE
    AFA HOLLYWOOD PREMIER LEAGUE EST. 1998
    Dothan, AL
    26 Apr 12
    Dothan, AL
    UPDATE! For those that dont want to scroll up.
    12 May 12
    Insanely Crazy
    Loganville GA
    looking good!
    Dothan, AL
    Well a valve seal or 2 needs to be replaced so I am going to remove the engine, respray the bay, replace the valve train, replace the HG, head studs, mild wire tuck, new clutch, and a few other things while I am at it.
    theMagician JGilbert312's Avatar
    Feb 2010
    Calhoun, GA
    Looking good, I really like EK hatches, and yours is looking really nice.
    that navi console is sex!!!! i like how clean it looks, does everything on it work??, even if not it still looks so clean and complete, how much did it run you??
    Dothan, AL
    Not everything works. I cant read Kanji either. Its mainly for eye candy. I found it CHEAP and I could resist.
    I have a Quaife 1.5 LSD on the way. My Crower Stg2 cams arrived yesterday and my ST dual valve springs, retainers, seals, valve guides, and flat faced valves will be in by the end of this week as well.
    Dothan, AL
    30 Jun 12
    Quote Originally Posted by AZN_Pride View Post
    30 Jun 12
    didn't know you had all this stuff orderd, hey man lmk if you wana get at the civic today i dont have anything planned. i do have to get some hardware for my car but thats it.
    Dothan, AL
    Quote Originally Posted by whatsacivic? View Post
    Why do you think I am broke? I bought a majority of that all in one month.
    I have plans today. Ill probably work on it on our day off this week. All I lack is the "Bitch" pin and the drivers side axle.
    95 civic
    blueridge
    lots of new stuff did you grab some cam gears the stockys stand out like a sore thumb
    95 civic
    blueridge
    car looks good tho
    no updates in a while hows the rebuild coming.... sounds like you need some motivation.... come on guys help this guy out he needs help car would be so dope!!! just my .
    Dothan, AL
    No new updates. I am considering g sellin this project and going with a carbed v8
    Dothan, AL
    13 Oct 12
    Dothan, AL
    Been a bit lazy, but here is where I am at now. About to pull the engine and start working on the bay and head. Afterward, it's the transmission.
    McDonough
    Looks great. I like that factory navigation. Cant imagine it was cheap or easy to come by.
    Sent from my Galaxy S3 using Tapatalk.
    Bitches love bacon.
    Dothan, AL
    Picking this project up again after moving. Just ordered a ported and polished PR3-3 head after finding out my original head has a chewed up cam journal. It is far from being able to be line bored. Also have been doing a lot of work since the last update.
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    this build is beyond epic
    Dothan, AL
    08APR13
    Dothan, AL
    15APR13
    Dothan, AL
    25APR13
    Dothan, AL
    12MAY13
    I got really bored today so I decided to mach setup the head and figure out where all the bolts go from Downstar. I also tact on a Sapporo beer cap on my Vtec Solenoid cover. I will get a cheap black one and do the same but with some compound we use in the Aviation world.
    I know I need to touch up a few areas on the head with some paint but that can be done later.
