Thread: halp, car shuts off
    Certified Gearhead oreign's Avatar
    May 2011
    Default halp, car shuts off
    My friend has a 2000 civic that likes to off randomly when driving. We changed the main relay and spark plugs but it still shuts off. When it does shut off, it usually turns on immediately but it can take a few mins at times. Could it be a dizzy problem?
    somewhere, GA
    Try a different MAP sensor.
    '82 TE72 SR5 Sport Coupe
    3tc
    Shuts off like Dash lights go off car quits running, or just motor dies but has all the lights on?
    1. bad igniter, cyp sensor (Cylinder Position sensor) Swap the dizzy with a known good one..
    2. Ignition switch going bad (like the key switch thing)!!
    No clue which to tell you, give more details
    Quote Originally Posted by oreign View Post
    May 2011
    As in, lights work but the motor dies.
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    Ignition control module, coil, computer, electrical short, crank sensor, fuel pump shorting. All possiblities.
    98 Acura Integra LS-DD
    ??????????????????-project
    May 2011
    fuckkkkkkkkkkkkkkkkkkkkkkkk.
    Heat This Side Down 90DB1's Avatar
    Start with the cheapest and work your way up
