Thread: d16z6 base map needed
    Default d16z6 base map needed
    i got a d16z6 i put in a 95 civic dx with a p28 ecu i am in need of a good base map the motor is bone stock
    Greene/Athens
    you sir, are running the correct ECU for that engine. Run your v-tec soleniod wires and your in business. No base map needed
    Edit: Unless your just trying to get something else out of this engine or have a chipped p28 with no chip.
    oh ok thanks all the wires are already there
    well it looks like i will be using a p06 the p28 i was getting fell through
    adding vtec to a p06 will require modification to the hardware portion of the ECU, there are places that can do it. you'd probably be better off just to buy a p28.
    Greene/Athens
    this is true but if your handy with a soldering iron I'm sure there is a write up on how to Add it. you can get the parts from xenocron.com
    But like he said, by the time you spend money on the p06 then the chip and v-tec add on hardware and pay someone to burn you a basemap you'll be better off just forking out for a p28.
    i have a p28 boss if your still looking
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    Quote Originally Posted by jadakid88 View Post
    i sold the civic allready and am getting my old 2g eclipse back but thanks anyway
