Results 1 to 1 of 1
Thread: S13 SR20DET long block Fully built and sleeved. Capable of BIGhp easy!
    Certified Gearhead M!SSBOSS's Avatar
    Default S13 SR20DET long block Fully built and sleeved. Capable of BIGhp easy!
    I have a fully built S13 SR Black top motor , long block only.
    This motor is capable for 600hp easily. only thing you need are injectors and engine management.
    Engine SPECS:
    Has less then 500miles on it.
    ACL Race Main and Rod Bearings
    ARP Mainstuds
    ARP Headstuds
    ARP Rod Bolts
    Machined, Balanced and Blueprinted Crank
    Eagle Rods
    CP Pistons 86.5MM
    Darton Sleeves
    Cometic HG
    Newer Timing Chain and All components
    New Water Pump
    New Oil Pump
    Greddy RAS
    272 cams
    Shaved Valve Cover
    Newer upper and lower oil pan
    PRICE $2000 FIRM.
    EXTRAs: $$$
    Unorthadox Underdrive Pulley
    Unorthadox Pulley Set
    300ZX Tranny With Custom Adapter Plate
    1 Piece Drive Shaft
    Turbonetics 62-1 Turbo
    Turbonetics Deltagate Wastegate
    Contact info:
    Carina
    6783347645
    Pics: THESE ARE PICS OF WHEN THE MOTOR WAS APART. IT IS IN THE CAR NOW. I have more pics of it currently in the car. Its going to be pulled out of the car tomorrow.
