Thread: Intake mani shooting flame
    Certified Gearhead Go_Fast's Avatar
    Jun 2010
    I-575
    Question Intake mani shooting flame
    I just installed a b20 in my gsr and it wont start. When I try to start it it makes a popping noise and shoots a blue flame out of the manifold (where the egr hose would connect). I know I have spark and fuel pressure. I think my vacuum is good, it should atleast be enough to turn over. I also had this same exact problem when I installed a b18 in the car a couple months ago. I thought the timing was the issue so I switched motors. Now im having the same problem. Ive also checked my grounds a million times and added extra ground wire but still nothing. Any ideas?
    It's wiring then, if you used the same engine harness, then junk it... Or I'd check CYP Circut in that harness, for some reason the dizzy if firing out of order...
    BUT for good measures also Check and double check the timing, including the firing order on the plug wires, and the order on the injector wires..
    Jun 2010
    I-575
    Quote Originally Posted by 1civic View Post
    BUT for good mIeasures also Check and double check the timing, including the firing order on the plug wires, and the order on the injector wires..
    will do thanks for the help
    Jun 2010
    I-575
    Anyone have an obd1 ls or gsr engine harness for sale?
    how about firing order on dizzy
    Or the timing belt. It could be off a tooth.
    Jun 2010
    I-575
    firing order is 4-2-1-3?
    im not sure if thats what it is or if that how i have it set up i gotta check later
    Quote Originally Posted by blown_ss View Post
    i think the timing is good the arrows and everything seem to line up perfectly but i'll keep it in mind
    thanks for the help guys
    LAWRENCEVILLE
    The firing order is 1-3-4-2
    Hella stock member!
    Quote Originally Posted by silversol View Post
    This man doesn't lie
    Jun 2010
    I-575
    im not sure what its set at right now ill check today
    At Home
    Sounds like welds on your manifold blew
    Jun 2010
    I-575
    Quote Originally Posted by WhiteAccord View Post
    i dont see any cracks on the manifold. where specifically would i look for a blown weld? and how would that happen?
    also the firing order has been 1-3-4-2 the whole time
