Thread: Boost Del Sol Build up!
    Jan 2010
    Northside
    Question Boost Del Sol Build up!
    Set-Up:
    Engine:
    Bisimoto Forged Connecting Rods
    Arias Pistons (9.1:1CR) (.20 over)
    Bisimoto Titanium Retainers
    Bisimoto Turbo Springs
    Bisimoto Custom 1.8 Camshaft
    Bisimoto Anti-slip Adjustable Cam Gear
    NGK Sparkplugs
    NGK High performance sparkplug wires
    255 LPH Walbro Fuel Pump
    650cc RC injectors
    .70 Autoworks Spec T3/T4 Turbo
    Go-Autoworks Full Ram Exhaust Mani
    Go-Autoworks 3" Custom Downpipe
    Tial WasteGate
    Tial BOV
    3 BAR MAP sensor
    Blox Performance Intake
    Ebay FMIC/piping
    Electronic Boost Controller
    Mircopolished Crankshaft
    OEM Head Gasket
    OEM Valves
    OEM Valve Gasket
    HaSport Billet 75 Motor Mounts
    Tuning:
    NepTune Tuning
    Transmission:
    D-series Tranny
    Competition Stage 4 6 puck Clutch
    2.9 Lvl Axels (DSS)
    Quaife LSD
    Suspension:
    Blox Traction Bar
    Tires/Wheels:
    Sacchi S.55/255 16" Rims
    Toyo Proxy 4 Tires (205/40/16)
    Drilled/Slotted Rotors
    Painted Brake Calipers
    Interior/Exterior:
    Glowshift Blue Digital Boost Gauge
    AEM Digital Wideband A/F Ratio Gauge
    Glowshift Blue Digital Oil Pressure Gauge
    Exhaust:
    3" Straight Exhaust
    MagnaFlow Muffler
    Extras/ Customizing:
    Tapped the Oil Pan for Oil Return
    Powdercoated Candy Blue Valve Cover
    I purchased this 1993 Honda Del Sol SI for $300 from a friend in need of money to pay his rent and an overdraft fee at the bank. needless to say i think i robbed him blink but that's what happens when people get despite.
    When i purchased the car the body was banged up pretty well, the crankshaft pulley was missing and half of the bolt that held the crankshaft pulley on was still inside the engine. NOTE: the kid i bought this car from also said to me when i asked when was the last time he changed the oil and i quote " you have to change the oil in a car?" so yea from day one this car has been completely rebuilt.
    When i finally received the Title for the car when took nearly two months, i tore the engine completely apart bolt for bolt.
    Immediately after pulling the engine out
    pretty burnt up
    The crankshaft was cracked and no good due to the crankshaft pulley disappearing in it's magic trick
    The bearings were scored hard
    Pistons were pretty much toast, burnt toast...
    Garbage Pistons and connecting rods
    Just a pic of how bad the oil was when i crack this open
    So after the complete tear down it was time to take the engine to the machine shop outside Schafferstown on 501 called Ober Performance - Machine Shop where i had the block and the head acid bathed, all the valves were replaced the block was bored .20 over and the notched to accommodate the larger connecting rods. With Vitara Pistons and the custom Connecting Rods fitted into the block snug, i bought a new Crankshaft and had it Mircopolished and checked structurally before that was installed. I also got the flywheel resurfaced
    i used ARP head studs to fasten the head to the block.
    once the head and the block were back together, i purchased a Stage 4, 4 puck disc Comp Clutch and a BLOX intake from IMW.
    I bought a Turbo and Exhaust manifold, altho i recently bought a Garrett Ball bearing turbo to replace this one.
    I ordered a 255 LPH Walbro Fuel pump and installed that.
    I then got the Valve cover power coated Candy blue
    I took the Transmission to have checked out, and everything seemed alright.So in the mean time the Del Sol looked like this:
    After awhile of not having any access to an engine hoist... it took four brave crazy people to hand drop the entire engine back into the car, and let me tell you it was a very odd experience...
    but the final result was not to bad...
    The next step was to take her to IMW to get her all set up and tuned. 650cc Injectors were installed and my iridium spark plugs were replaced with NGK spark plugs. an electronic boost solenoid was installed and everything else that was needed was added, it was time to DYNO Tune the Del Sol when Johns computer picked up that the number 3 cylinder was not firing correctly... we tested spark, and fuel they were both a go, after a disappointing ordeal we found out that there was an 80% compression leak in the Head... I bent a valve trying to start it when the firing order was incorrect.
    Most recently, I tore the head back off and took it back to Ober's and had all the valves replaced lucky for me i decided not to put the Head back on before I was deployed because now i am looking into purchasing a racing camshaft and new retainers and spring that will be installed by Ober's performance.
    Small odds and Ends are also being purchased while i am way such as drilled and slotted rotors, HID Headlight Kit, and a high security Alarm system...
    When i get back in February it should take me about a week to finish up what i have to then it is back to IMW to get a fresh tune with the Garrettball bearing turbo installed, and no compression leaks...
    This is what i have done and what i want to do, if you have any advice for me i will gladly accept it and consider it thoroughly. i am no expert and i am still learning.
    Aug 2009
    nice
    Jan 2010
    fayette
    ^x2
    97 Del Sol VTEC
    Certified Gearhead SRDFTITAN's Avatar
    Nice bro good job, I'm glad they finally gave us a build thread section!!!
    Scott Racing & Development Factory (SCCA Auto X/NASA HPDE)
    Build thread:http://www.importatlanta.com/forums/...GAUGE-HOLDER**
    Titans member#0001
    Apr 2011
    Nice, I'm glad to see a single cam!
    *Save the Single Cam*
    Kinda lame IRL isa2o3's Avatar
    I had similar setup on a EK some years ago. Fun as hell
    those look like vitara pistons to me. especially since they have the arrow toward flywheel side.
    =) JF868849's Avatar
    Oct 2008
    BYRON
    thats what i was thinking
    h22?
