Thread: CEL On Nissan 240sx OBD1 1995
    Emergency Medical Tech
    Oct 2003
    Duluth,Ga
    Default CEL On Nissan 240sx OBD1 1995
    I had CEL on on my OBD1 nissan. It reads code 34 and 105. I reset the code without fixing the problem which is knock sensor and egr valve. The CEL didn't turn back on. Is the sensor just reading wrong or should I replaced the parts that cause the light to came on?
    Help pls before I order the parts.
    You don't know how STRONG you are until being strong is the only
    CHOICE you have!
    'Born Ready!',LJ
    It will sometimes take 2 solid drive cycles for the codes to come back on. Maybe longer if they are intermittent codes. obd1 ecu are dumb, usually the only time they set a code is if there is an open in the circuit or the resistance wrong.. check your grounds and stuff just in case.
    Oct 2003
    Duluth,Ga
    What do you mean by 2 solid drive cycles? Like crank the car and drive it twice?
    Update: i drove it a bunch and no cel. But i replaced the o2 sensor just now and the light came on. The code wasnt for the o2 sensor but i replaced it anyway since it's over 100k miles.
    Do i have to reaet the ecu everytime i replaced a sensor? Gonna pull up the codes again later to see whether it's the same on.
    CHOICE you have!
    'Born Ready!',LJ
    yeah some ecu require the vehicle to go through 2 drive cycles to set a code.. usually a short drive.
    theres no point in replacing an o2 due to mileage unless youve got a running issue.
    you shouldnt have to reset the ecu over a replaced sensor unless it was causing a CEL
    Oct 2003
    Duluth,Ga
    Awesome! Thanks man!
    So if i check the sensor, and it's good, does that mean that my engine is knocking? It drives fine..
    CHOICE you have!
    'Born Ready!',LJ
    No it means you need to check the wiring from the sensor to the ECM.
    Oct 2003
    Duluth,Ga
    Gotcha. Will do it and give updates.
    CHOICE you have!
    'Born Ready!',LJ
