Thread: Brakes!?!?
    Feb 2012
    Default Brakes!?!?
    I have a 93 Del Sol Si and as of yesterday, my brakes started going to the floor if I put pressure on slowly, but would hold if I pumped them fast in a "panic stop." There are no leaks from my master cylinder, my brake fluid is still full, my pads are good, no CEL's, and no vacuum leaks.
    No brake service has been down recently, so I doubt it is air in the lines.
    Thoughts and fixes?
    Thanks IA
    Conformer.
    Youve either got slide pin on a caliper thats stuck or your master cylinder is going bad.
    Feb 2012
    I'm going to change the master cylinder. I found a new one cheap, I'll work from there...
    Unless there are other opinions?
    Conformer.
    Feb 2012
    BUMP
    Conformer.
    did you check your caliper slide pins?
    Feb 2012
    Yeah, theyre all good. Calipers work fine.
    Conformer.
    Time for a MC then
    Feb 2012
    Ordered. Thanks!!
    Conformer.
